Solid Axle to TTB?
Old Apr 4, 2025 | 02:56 AM
  #31
Stonebacon69399's Avatar
Stonebacon69399
Originally Posted by JJF20
Not to throw a wrench in… but, you’ll will probably have to relocate the body mounts on the frame, as they did on the other frame to mount the dent body.
You’ll have a mix of three different generations of trucks going, not that it can’t be done… but…
Well I dont think it would be all that much different putting the dentside body onto the bullnoses frame unless the bullnose cabs are alot different than the bricknose cabs.
If I end up swapping the body and bed onto the bullnose I wouldnt be using any parts off of the bricknose itself.
I seem to remember reading about putting the dentside body onto an obs chassis and all it took was the body mounts to be welded on the front and the rear mounts were the same or something.
I should be able to just copy what was already done on the bricknose chassis.
Robert6401
Oct 24, 2016 11:46 AM
dohc_chump
Feb 4, 2011 08:24 PM
godblessmud
Offroad & 4x4
29
Nov 19, 2007 02:18 PM
prisoner of gravity
Jun 29, 2006 10:02 AM
Haulerdriver
Feb 3, 2004 02:06 PM
