Sponsored by: Real Truck
Steering issues on ‘15 4x4
Old Mar 31, 2025 | 08:09 PM
66 bronco roadster's Avatar
66 bronco roadster
Ok this has been happening for a couple years and at first it’s was once in a great blue moon now it’s might happen once on every drive but still intermittently.
So it will be fine until a take a fairly sharp turn. Then the steering wants not to return back to center. I have to forcibly steer it back to center and even then it still wants to pull towards that side.
I have taken it to a shop and both times it didn’t act up. The tie rod ends have been replaced and both times they said the front end it good.
What should I look for???
Bad power steering pump
Bad steering box
Bad front axle U-joint
Air in my power steering system
Bad steering shaft U-joint or coupler
Bad radius arm bushing
Im guessing here because it’s stumped a few people and I want to get finally fixed once and for all.
Old Mar 31, 2025 | 08:35 PM
Pikachu's Avatar
Pikachu
Check your front axle u joints first. Turn the wheels a bit to one side or the other. With the hubs unlocked, use a prybar or similar to turn each axle shaft. They should turn a complete revolution without significant binding.
Old Mar 31, 2025 | 09:23 PM
66 bronco roadster
I will check that tomorrow. I know the passenger side was replaced about 4-5 yrs ago I probably should’ve done both. But I’ll check them both to make sure. Thanks
Old Apr 1, 2025 | 10:34 PM
66 bronco roadster
Yep the passenger side axle I turned / rotated fairly easily while the driver’s side I couldn’t budge!
Old Apr 2, 2025 | 06:13 AM
Pikachu's Avatar
Pikachu
Well, then there you have it!
beersy50
Dec 12, 2023 12:17 PM
jgavac
Aug 18, 2020 02:35 PM
Ronnie Basil Smith
19
Aug 11, 2016 01:01 PM
THE KING
Jun 14, 2007 10:31 PM
sfd4
Jan 9, 2006 07:23 PM
