Interesting Steering
Old Jun 13, 2007 | 05:20 PM
THE KING's Avatar
THE KING
I bought a 1973 F-250 High boy and im in shock about the steering in this beast. It has a normal looking steering box but where the pitman arm would just drop down and go to the steering rods it goes through the frame to a hydralic looking pump with a shaft going to the spindal. Then the hydraulic lines run to a steering stablizer! Wut the heck is this! Im thinking the front axle is a 44 HD. Its very interesting and when its sitting there and i turn the wheel a little i have a lot of play on that pitman arm to that other pump. Where could i find parts?
Old Jun 13, 2007 | 06:37 PM
prrcatenary's Avatar
prrcatenary
That sounds like the power assist steering used on the earlier 4x4's, later all used the integral power steering gearbox.
Old Jun 13, 2007 | 06:46 PM
THE KING's Avatar
THE KING
Yea its really interesting. I had my 79 Bronco that would have loved this steering system.
Old Jun 13, 2007 | 10:33 PM
Jermafenser's Avatar
Jermafenser
Yep, it's called Linkage Power.
It's a ram-assist type steering. It's generally inferior and problematic when compared to the '77 1/2-'79 integral power steering.
Old Jun 14, 2007 | 01:34 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Actually its a pretty good steering setup if its working right. You get tons of power to turn the tires from that big ram but there are so many moving parts that a little wear here and a little there really add up to one sloppy steering. One big problem is the little u-joint on the steering shaft.
Old Jun 14, 2007 | 10:31 PM
AZ_Catskinner's Avatar
AZ_Catskinner
Technically, if it's working right, it is a FAR superior system to the power steering gearbox.
Heavy equipment, and many heavy trucks still rely on the ram assist.
