7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Engine Lope after start up
Old Mar 31, 2025 | 02:11 PM
Akdan's Avatar
Akdan
6th Gear
Hi folks thanks in advance for throwing out some input.
I have been battling a hard lope on cold start ups since new on my 22 7.3 250 (27000 miles now). It occurs about 15 seconds after start and lasts for about 5-20 seconds on cold starts at temps under 40 degrees F. It has been to the dealer many times trying to resolve it. I was told it was normal for the first few visits. On the last visit they started looking into the engine and found the cam was significantly worn and a scored cylinder. The wear was significant enough that the engine was replaced. On my first cold start the lope reoccurred so it is either something in the programming or possibly in the transmission. The transmission has had a lot of weird noises(one even recorded by the computer) and behaviors(sticking in gears-happened 3x on down grades), occasional banging into another gear, and most often a complete stumble between 3/4&3/5 gears. According to the dealer everything checks out and my trans issues have never been duplicated. I have a suspicion that the transmission/torque converter is the problem, but haven’t made any headway. Any of you experience something similar?
thanks
Dan
Old Apr 1, 2025 | 12:22 AM
charlie g's Avatar
charlie g
FTE Community Team
in my dealer service experiences a short cold lope is common, as the sensors start coming more on line, try writing a pm to https://www.ford-trucks.com/forums/member.php?u=958174 that is our site ford rep who MAY be able to help ,advise you better
Old Apr 1, 2025 | 06:30 PM
scraprat's Avatar
scraprat
Top Answer: 5
Transmission won't have anything to do with it on start up .
Transmission sounds like it's own issue.
Old Apr 1, 2025 | 08:46 PM
leadmic's Avatar
leadmic
Sounds like the cam phaser might be slow to react when its cold.
Old Apr 2, 2025 | 06:27 PM
Akdan's Avatar
Akdan
6th Gear
Thanks for the reply’s, the reason I was thinking it could be the transmission is due to the severity of the lope/surge. It moves the entire truck and acts/sounds as though the engine is coming under load, then unloading, then loading again for a for about 20 seconds. I have chased timing and vacuum leak is on other vehicles and it’s very different. It is a similar motion to something off balance. It is also strange that it did it on the old engine and with the new. The start and idle characteristics of each motor is slightly different, much better with the new motor
Old Apr 3, 2025 | 11:17 AM
Dozzer's Avatar
Dozzer
Weird I remember when the 7.3 first came out people saying it would lunge forward in park on start up. I don’t know anything about Transmissions but I wonder if the torque converter is slightly locking and unlocking causing an on off load on the motor?
Cougar6
Jul 7, 2023 11:53 PM
T diesel
6.2L V8
45
Jan 9, 2017 05:11 PM
Restlesswildman
Dec 8, 2013 11:13 PM
the almighty schmuck
Jul 20, 2011 09:18 PM
777tcsrdb
1983 - 2012 Ranger & B-Series
Oct 5, 2004 07:53 PM
