Distributor not clearing thermostat
Old Mar 31, 2025 | 10:17 AM
dawsonmcgill1985's Avatar
dawsonmcgill1985
Trailering
Thank you to everyone that responded to my previous thread. I am building a 460 and I was trying to install an HEI distributor and I was stopped because of the thermostat housing getting in the way of the distributor sitting all the way down in the block. I tried rotating the distributor around but still could not get it to clear. Is there a different thermostat housing I could get so that there would be enough clearance for the distributor? Thanks so much. Dawson.
Old Mar 31, 2025 | 02:40 PM
Franklin2's Avatar
Franklin2
They make this thermostat for the people with interference problems on the 460.
https://performancedistributors.com/...LVZ_zkP4&gQT=2
Old Mar 31, 2025 | 03:43 PM
FuzzFace2's Avatar
FuzzFace2
And you found out why the HEI is not the best dist. to be using in anything not GM.
What was wrong with the DS II dist. and if you are swapping in the 460 in place of something else you could have bought a DS II for a 460 that would have cleared.
Dave ----
Old Apr 4, 2025 | 04:47 PM
351Cleveland C4's Avatar
351Cleveland C4
Dave ----
Exactly this...
You have created your own problem. The solution is to use the correct distributor.
Old Apr 4, 2025 | 05:49 PM
orange65's Avatar
orange65
Believe to be the same as mentioned above:
Dorman 902-1033
gweedo295
34
Mar 2, 2024 05:45 AM
Rotorpilot
Mar 18, 2023 09:47 PM
diggerrigger
Nov 6, 2021 07:52 AM
Lucky78
Aug 9, 2017 08:52 PM
Speedymaru
67
Aug 14, 2016 11:43 AM
