Distributor fitting
Old Mar 18, 2023 | 03:26 PM
Rotorpilot's Avatar
Rotorpilot
Distributor fitting
Need some help guys. I installed a Weiand 8012 Stealth on my 86 F250 460. The performance distributor I have now won't fit. The cap hits the thermostat housing. Will a Stock distributor work or is there a different designed housing that I can get to clear the cap on the Performance distributor. Any advice will be appreciated.
Old Mar 18, 2023 | 08:01 PM
FuzzFace2's Avatar
FuzzFace2
Why did you swap out the factory dist. did it have vacuum advance?
Also what did you replace it with?
Got a picture of how it dose not fit?
Dave ----
Old Mar 18, 2023 | 09:47 PM
Franklin2's Avatar
Franklin2
I am assuming your different distributor is a HEI unit? They are larger in diameter. Check the people that you bought the distributor from, they make a special thermostat housing to fit the larger HEI distributor. Here's a link. https://performancedistributors.com/...ostat-housing/
rswhitmore
Mar 16, 2022 09:16 AM
Prionus
16
Mar 1, 2022 05:08 PM
chris989
Sep 19, 2021 07:52 PM
cparks
Apr 18, 2009 06:57 PM
dillon1033
Feb 9, 2003 12:52 PM
