Duraspark distributor cap too large...conversions?
Old Jan 26, 2017 | 05:59 PM
Lucky78's Avatar
Lucky78
Howdy fellas, my distributor cap on my 460 is riding against my thermostat housing. I installed an over priced slimmed down neck, but I still don't like it pushing on the cap. It's such Tight fit...I feel like there oughta be a smaller cap conversion out there. Anyone dealt with this issue?
Old Jan 26, 2017 | 11:01 PM
wdfp's Avatar
wdfp
You could get an aftermarket distributor or a different thermostat housing. There is a housing made that has the side sloped off that clears everything quite well, It was used on later 460's I think. If the housing you have is thick enough you might file or grind some clearance that way too
Old Jan 27, 2017 | 12:02 PM
redmt79's Avatar
redmt79
Correct, use a thermostat housing from an '83-newer truck 460. Napa, Oreillys and others list them for around $20. This is a picture of what the chamfer looks like to clear the large cap:
Old Jan 27, 2017 | 01:10 PM
Lucky78's Avatar
Lucky78
That's the ticket, I don't know why I didn't find that housing when I was shopping. I had this motor in a boat...so I had a block off plate and never had a housing. Thanks guy's.
Old Aug 8, 2017 | 01:20 PM
jniolon's Avatar
jniolon
old and in the way
Lucky.... I got the same problem with a Davis DUI... did you solve the problem ?? what dd you use ?? That looks like a Billet Specialities housing. I was about to drop the hammer on one today...
what was your solution
thanks
John
Old Aug 9, 2017 | 09:56 AM
Lucky78's Avatar
Lucky78
Hi John, I'm running it like you see it. It's fine but would look into that Napa housing with the relief in it.
Old Aug 9, 2017 | 08:36 PM
Kruse's Avatar
Kruse
Check the applications for early to mid '80s Ford E250 or E350 vans that have the 460. Dorman 9021048 might be the ticket.
Old Aug 9, 2017 | 08:52 PM
jniolon's Avatar
jniolon
old and in the way
found an answer... here's what we made
little bit of tig work and ss fittings... BAM gonna go back and add a bead around the end to hold the hose.
j
Aaron-71
Dec 13, 2017 10:03 AM
Speedymaru
67
Aug 14, 2016 11:43 AM
hank790
Apr 6, 2007 08:45 PM
6Fastback7
Oct 7, 2006 06:58 PM
deanme
Aug 29, 2005 12:06 AM
