Choosing a new ECU
Old Mar 29, 2025 | 11:34 AM
desertprep's Avatar
desertprep
Choosing a new ECU
I have another thread here about improving engine performance - thank you all for your contributions. I have a new question about the next step. In addition to improving engine performance, I want to install an automatic transmission (that is most of the reason for needing more performance). If I want to break the limitations of the present ECU, I will have to buy another one. If I put a E4OD or a 4R100 in, I will need to install some kind of electronic device to help the engine "talk" to the transmission. If I am buying a new ECU, can I find an ECU that will also do that function, i.e. communicate with the transmission as well as controlling the engine, so that I don't have to buy two devices?
Old Mar 29, 2025 | 12:18 PM
rla2005's Avatar
rla2005
Stinger Performance Pimpxshift is what you are looking for. A few folks on this forum are using their products.
Old Mar 29, 2025 | 12:44 PM
desertprep's Avatar
desertprep
Thank you! Does that work with the ECU or can it replace it?
Old Mar 29, 2025 | 01:03 PM
Conanski's Avatar
Conanski
It replace a factory ECU that would control both engine and trans.
Old Mar 29, 2025 | 01:38 PM
desertprep's Avatar
desertprep
Are there other options? especially something around $900?
Old Mar 29, 2025 | 02:12 PM
Scndsin's Avatar
Scndsin
For 900 or so you can get a PimpX that runs the engine & 400 more you can get a PimpXshift that'll control a trans. (at least it was)
Made of 100% new components except for the case it comes in.
And that's going to be close to market standard for any tunable control only system.
Old Mar 29, 2025 | 03:45 PM
rla2005's Avatar
rla2005
As stated previously any aftermarket controller that can handle the engine and electronic transmission is not cheap. Price just a transmission controller for comparison.
Staying factory is cheaper but does limit the HP/TQ goals and custom transmission shifting.
Ron in NY
27
Aug 6, 2021 06:35 AM
Catherine Irene Schultis
Engine Swaps
Apr 26, 2021 08:34 AM
ZAR2USA
Jun 13, 2017 09:29 AM
Ford_Six
13
Dec 29, 2002 02:40 PM
