Sponsored by: Real Truck
Cover
Old Mar 28, 2025 | 10:59 PM
tws3's Avatar
tws3
7th Gear
Cover
2003, f250, 5.4 regular cab xl. Where the top of cab connects to the rear pillar on each side. There is a plastic cover that hides the seam/joint. I have no idea what it would be called except " plastic cover". I can find hoods, grills, doors and fenders and much more online but not that little cover. Anybody have idea where I could find?
Old Mar 29, 2025 | 06:34 AM
Pikachu's Avatar
Pikachu
Molding, Roof Side. I can't find a complete part number, but Ford's callout for it is 51728. It shows as not available, but a dealer might be able to locate one as NOS or through an aftermarket body supplier.
Old Mar 29, 2025 | 10:36 AM
madsonp's Avatar
madsonp
Is this what you’re looking for ? https://www.ebay.com/itm/32440262039...7d6a52ac563fe5 Here’s a place that has a video on replacing them. https://motorriderz.com/2019-ford-f2...g-replacement/
Old Mar 29, 2025 | 10:56 AM
tws3's Avatar
tws3
7th Gear
Yeah, looks like. But wrong year 08-16. Mine 03. But give ideas where to look.The video of how to install will help when I find one to fit.
Whoops, hold on.
I just found a pair on ebay. I think.
Old Mar 29, 2025 | 12:46 PM
madsonp's Avatar
madsonp
Whoops, hold on.
Old Mar 29, 2025 | 01:59 PM
tws3's Avatar
tws3
7th Gear
Yep, I found it on ebay.
Thank Guy's. I appreciate.
Old Mar 29, 2025 | 02:29 PM
madsonp's Avatar
madsonp
Be sure to let us know how they work out for you.
Old Apr 6, 2025 | 10:47 PM
tws3's Avatar
tws3
7th Gear
Well I finally got the corner molding on. Took me over a half day. Most of that time was trying to get the plastic trim out of the way without breaking the 20 year old plastic. Everything on passenger side from the roof light over had to move so I could get headliner down to where I could get to the two screws in the corner. The hand hold on the front pillar, the hand hold above the door, sun visor, front pillar cover, rear pillar cover, hook, seatbelt, door seal and door threshold cover all had to move. All had to move just to get the headliner down about 8 inches. Even the jackass on the hook had to go. A 6 inch 1/4 driver with 11/32 deep socket was the tool needed. But it's done.
Old Apr 6, 2025 | 11:30 PM
madsonp's Avatar
madsonp
Well, it looks like they fit good. Thanks for the follow up.
Old Apr 7, 2025 | 10:36 AM
tws3's Avatar
tws3
7th Gear
The molding is pretty flexible and one of the bolt holes is elongated so that when the nuts are tightened the molding can nestle itself down against the cab pretty good. Installing the molding was the easy part. Getting all the other stuff out of the way was not so easy.
Mike in CA
Sep 11, 2022 03:36 AM
Winter2
2021+ F150
Aug 14, 2022 12:11 PM
dugals
Dec 11, 2021 11:09 PM
