Truck will not start after replacing turn signal switch
Old Mar 27, 2025 | 05:12 PM
Nathan Ungerman's Avatar
Nathan Ungerman
1st Gear
I recently bought a 1993 f250 xlt with a 460 engine and have been doing some work on it.
I just replaced the turn signal switch because the turn signals and wipers barely worked and I traced the problem to the switch. After installing the new switch I went to start the truck and all it will do is crank. I can hear the fuel pump working and the engine is cranking just not starting, and it ran perfectly fine before replacing that switch.
Im still pretty new to ford trucks and Im very confused. Any suggestions?
Old Mar 28, 2025 | 01:56 AM
Prototypemech's Avatar
Prototypemech
The switch can't prevent your engine from starting. There's no wires that go from the switch to the ECU or engine component.
It's more likely that you bumped or damaged your near-by ignition switch, which will definitely affect your engine.
Check for spark while you're cranking your engine, and go from there.
Old Mar 28, 2025 | 09:19 AM
manicmechanic007's Avatar
manicmechanic007
+1 for that
Those ignition switches also can come apart and even start the truck on fire
The testing...
They call it interrogation
You interrogate that ignition switch by moving the wire connector around while you cycle the key back and forth
Act like a 2 or 3 year old kid and go after it with the key and wiring
Old Mar 28, 2025 | 09:57 AM
Scndsin's Avatar
Scndsin
When you turn the key to on & not start, does the pump run 1-2 seconds & stop or continue to run?
Have you checked to see if there is spark when it cranks-no start?
Do you know where the SPOUT plug is below the diagnostic connector under the hood?
Is the switch you replaced at the base of the steering column? (edit, sorry, another thread)
Jamon Norton
Feb 22, 2024 09:27 AM
Junktownbill99
18
Nov 28, 2023 09:21 PM
smdl
2009 - 2014 F150
19
Nov 6, 2021 09:50 AM
firewood truck
Mar 17, 2012 01:46 PM
cjmedina
Bronco II
Jan 17, 2006 04:21 PM
