no spark 1990 460
Old Mar 26, 2025 | 08:47 AM
highpockets58's Avatar
highpockets58
no spark 1990 460
I have a 1990 Super Duty roll back with the 460 engine. I seldom drive it and never in the winter. But, it always starts right up in the spring, not this year. I checked the coil wire at the dist. cap end and there is a single weak spark about every revolution. I swapped a ignition module that I am quite sure is good, same result. I pulled the distributor cap and the metal trigger wheel (not sure if name is correct) and it was surface rusty. I removed it and cleaned it up. Cleaned up inside the distributor and the same weak occasional spark. I ordered a pick up coil but haven't installed it yet. I watched some videos and it looks like removing the dist. gear can be a problem. Is there a way to check that pick up coil before I dig in? Could anything else cause that issue? Thanks in advance.
Old Mar 26, 2025 | 08:53 AM
samuel4wolfpack's Avatar
samuel4wolfpack
In my experience with this forum, I usually see that Motorcraft is the go-to brand for these ICMs...
Old Mar 27, 2025 | 04:12 AM
manicmechanic007's Avatar
manicmechanic007
Do replace the stator in your distributor just for GP's (the pickup)
Once done with that and if the problem still persists, check the processor capacitors
The gear and collar if equipped are a bit difficult, but easier with a press
I just used a brass hammer for years and years, sometimes a press will break the distributor body
Make line up marks for the gear and shaft with a file to help you get the gear and collar back on there exactly right
Most of the time, the roll pin hole is not drilled exactly on center
That means if you install the gear 180 out, the roll pin hole will NOT line up correctly
Old Mar 29, 2025 | 05:25 PM
highpockets58
Swapped in a new distributor and it fired right up. Thanks for the tips.
Jerf
Mar 23, 2024 02:40 PM
F100Gasser
45
Jul 19, 2021 07:59 AM
OldFord99
Modular V8 (4.6L, 5.4L)
Sep 10, 2017 06:18 PM
treiver123
Engine Swaps
Mar 30, 2009 03:09 PM
circllb
Feb 19, 2009 09:06 PM
