wiring problems
Old Mar 29, 2009 | 12:02 PM
treiver123's Avatar
treiver123
wiring problems
i put a 460 into 92 f250 that had a 351 and i cant get any spark i get power to coil and to the cap but nothing out of wire terminals and im not sure were the wires distributor goes
Old Mar 30, 2009 | 07:27 AM
HogginNboggin9's Avatar
HogginNboggin9
what year truck did the 460 come out of, and did you use an ohm meter to test the coil to see if there is an open in it, because if there is an open in the coil its obviously not gunna give off any spark
Old Mar 30, 2009 | 01:37 PM
treiver123's Avatar
treiver123
the 460 is 85 and not sure what an open is had about 12 volts out of coil wire
Old Mar 30, 2009 | 03:09 PM
HogginNboggin9
did you try taking off the distributor cap and looking at the condition of the cap and rotor maby its not getting a good connection to the caps terminals if ur saying the cylindrs arent getting spark
