460 highboy conersion
Old Mar 25, 2025 | 10:22 PM
Jgrove762's Avatar
Jgrove762
Hi there I have a 74 f250 4x4 with 360 and 4spped manual, I want to swap in a 460. I'm wondering what parts are needed to make this swap work? thanks
Old Mar 26, 2025 | 07:46 AM
440 sixpack's Avatar
440 sixpack
Nothing will bolt up. convert your 360 to a 390 and you're better off in every way.
Old Mar 26, 2025 | 08:33 AM
Jgrove762's Avatar
Jgrove762
I've heard this and have considered building FE into a 410 or 445. Why I be so much better off with the FE as opposed to going with a 460?
Old Mar 26, 2025 | 08:55 AM
fe390pc's Avatar
fe390pc
You just need a 460 bellhousing, and verify that your "Z" Bar mount from the 360 bolts to the 460. I am partial to the FE but those 460s are a good engine and have a lot of support still.
Old Mar 26, 2025 | 08:56 AM
wademo's Avatar
wademo
You would be amazed by the torque of a nicely built 410!
Old Mar 26, 2025 | 09:25 AM
fe390pc's Avatar
fe390pc
Oh, I have no doubt at all. Its just getting harder to get good parts for these FEs. When I built my 390 it was peanuts, I bet it would be over $3K for the very mild build i have now!
Old Mar 26, 2025 | 09:36 AM
Rubiranch's Avatar
Rubiranch
410/428 crankshafts are hard to come by.
Rebuilders or parts companies that have them require a good core in exchange.
Old Mar 26, 2025 | 08:14 PM
440 sixpack
The FE is not a problem to rebuild, the heads can be a bit more expensive to work on but that's the main difference.
by the time you buy the conversion parts and morgify your exhaust for the 460 you won't save any money. and your pickup will retain more value with the Fe as well.
Old Mar 27, 2025 | 11:34 AM
Greaser007's Avatar
Greaser007
Well, I was just perusing thru our local Pick-n-Pull yard website two days ago and they have a '72 Thunderbird with a factory 429.
That would be a nice choice for an F250.
The FE 390 block with a 428 Scat crank kit would be a nice power plant engine for all-round good times.
Some of the mid '80's Ford E-series Vans had nice 460's with Holley 4-bbl carbs or EFI for choices.
Below is a random engine rebuilder with what appears to be a reasonable Long-Block price at $2,600.
FOR-390LB-3
Now, I pulled the original 400M engine from my '77 F350, and installed a built-and-balanced inline 300-six Gasser. LoL
The reason for the inline 300 six with Clifford induction and exhaust, was for the Nostalgia. 300's are not Liip-Rippers.
Old Mar 27, 2025 | 11:42 AM
tbear853's Avatar
tbear853
No question in my mind, if a 360 engine come out, it would be a 390 going back in. Maybe a 410 or 428, but yeah, a 390 will do very nicely.
I would not even consider swapping a 460 into mine in place of the 351M in it now, and there is less hassle involved there than is going from a FE to 385 series.
Old Mar 27, 2025 | 12:09 PM
Rubiranch's Avatar
Rubiranch
A friend of mine installed a 1969 429 2V in his 4wd.
The 2V 429 produced something like 460 lb ft of torque at 2200 rpm. It pulled like a tractor.
The 4V didn't hit peak torque until something like 2800 rpm.
The 429 2V would be my choice.
Old Mar 27, 2025 | 05:30 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
A 72 429 is a dog.
Garbage combustion chambers and low compression. My dad took a good running turd of a 400 out of his 79 Bronco and put a 429 out of a 72 T-Bird in it. He regretted it from the test drive.
Old Mar 27, 2025 | 06:50 PM
440 sixpack
I put a 429 out of a '73 Mercury in place of the dead 55,000 mile 400 in my dad's '79 f250 4x4 in `1988. I just rebuilt it last year to stock specs and it runs better than it ever did.
Like the smogger 460's , the base429's were not that impressive. neither were the 454's or the pickup 440's at the time. but they would all smoke a 400..
Old Mar 28, 2025 | 09:35 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
To be fair, the 400 in the Bronco (owned since new) was equipped with fenderwell exit headers and an Edelbrock intake/cam package. Unrelated to performance, it also got new rod and main bearings at 61K miles (big surprise). It ran really well being in a light Bronco.
Dad was like I am....can't leave good-enough alone (I know where I get that trait)......so he procured a wrecked 72 Thunderbird in the mid 2000s and bought all the same goodies (L&L fenderwell exit headers, Edelbrock intake/cam) and it NEVER ran as strong as that 400.
I **** talk the 335 series all the time for good reasons; they are trash. However, I'd shy away from a stock low compression 460/429 if one is expecting a real difference in power/economy. They also suck.....and as 440 sixpack stated, ALL early emissions and most truck-application engines suck.
Old Mar 28, 2025 | 09:54 AM
440 sixpack
It was a sad era for performance even in the sportier cars. but the 351-400 stood out as awful even among the pigs.
A stock smogger '72 429 produces only 212 hp and 327 lbs of torque, pretty sorry. until you look at a stock 79 400 that gave 158 hp and 276 lbs of torque. this was the peak of pathetic Ford engines.
