Sponsored by: Real Truck
Body mounts.
Old Mar 25, 2025 | 09:19 PM
Dzlinmyblud72's Avatar
Dzlinmyblud72
4wd Low
Body mounts.
Hello, I’m looking to replace my cab mounts. Having a difficult time finding the correct ones. Dorman only makes ones for position 1 and 3 is what they said. I’d really like to get the OEM part numbers for all of them hardware included. Door sticker says build date is 02/03. Ford f250 crew cab. Any help would be appreciated thanks.
Old Mar 26, 2025 | 07:30 AM
Dan V's Avatar
Dan V
Just get the ones from S&B...pay once, cry once.
Old Mar 26, 2025 | 09:37 AM
Pikachu's Avatar
Pikachu
I'd avoid Dorman products, especially when it's a part that takes more than about 2 minutes to change. I've installed the S&B mounts, and they are pretty high quality, IMO.
Old Mar 26, 2025 | 01:30 PM
MountainCamping's Avatar
MountainCamping
Trailering
I also recommend S&B. I have them and they are top notch!
Old Mar 26, 2025 | 02:08 PM
Antonm23's Avatar
Antonm23
I say pick your favorite manufacture of polyurethane body mounts (link below to just one example). The ride is not noticeably different from stock body mounts (the truck's suspension is responsible for ride quality), they're WAY cheaper than the silicone offerings, and they'll last literally forever.
Some trolls will probably get on here to say they squeak because they read that online somewhere and will repeat it like a parrot. That is simply not true because to cause a squeak there must be relative motion between two parts. So yeah, a suspension bushing made of polyurethane absolutely has the potential to squeak, squawk, and make all kinds of racket because the suspension parts move relative to the stationary polyurethane bushing. If you've got relative motion on the body mounts , then the cab is falling off the frame and the squeaking is the least of your concerns.
I'm on my fourth truck that I've replaced the stock body mounts with poly ones (because the stock mounts just disintegrate after about five-ish years), not one squeak or any noise ever and not even my princess of a wife can tell any difference in ride quality.
https://www.energysuspensionparts.co...SABEgKZCPD_BwE
Old Mar 26, 2025 | 02:22 PM
Overkill2's Avatar
Overkill2
When mine need replacing, I'm going S&B as well, I was going to go with SPE's mounts until I saw this video:
Old Mar 26, 2025 | 02:51 PM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
Shoot me your VIN, I can give you all the OEM part numbers.
-Steve
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Old Nov 15, 2025 | 08:06 PM
Dzlinmyblud72
4wd Low
-Steve
1FTNW21P23EC41772
gtex
Oct 1, 2020 06:42 PM
Dan V
Oct 1, 2019 09:57 AM
seagull369
1983 - 2012 Ranger & B-Series
Jun 21, 2015 10:44 PM
ralphatlarge
Oct 14, 2013 09:17 PM
Black X
Jan 28, 2010 07:06 PM
