I've had the body completely lifted off my Excursion (look at the link in my signature for pics)... However, I dont Know if the F-SD mounts are the same. I'm guessing the cab ones match perfectly, but the bed ones are different. Seems to me the rear Ex. mounts were similar or the samre as the front cab mounts. So possibly 2 F-250 kits would work... but i never pulled the mounts off the chassis for a closer look.
EDIT: I still have a bare chassis in by back lot, I will compare front and back for you when I get a chance...
Reason: research
Thanks for the info! I got a poly body mount kit for a 2003 f250 and it had 8 mounts that were the same and 2 that were dirrerent .i am hoping the 2 different ones are for the front and the other 8 are for the rest
I just looked at the chassis outside. The two different ones are at the very front on the radiator support hoop, where it mounts to the chassis (these have a stud sticking up out of them). The other 10 appear to be all the same, unless there is a slight height difference that I could not see - did not measure. Hope that helps
