EEC Relay Help
Old Jul 20, 2021 | 08:52 PM
xr4000's Avatar
xr4000
EEC Relay Help
So I have a 1990 f250 that was getting no spark. After searching around a bit I found that the EEC relay is a common problem so I went to investigate. Upon inspection I saw that the two yellow wires coming out of the port where the EEC relay connects were corroded and broken off. My question is does anyone know the name of this piece? Is it as simple as the EEC relay port?
Old Jul 20, 2021 | 08:56 PM
SFaulken's Avatar
SFaulken
Uh, Where does that plug into? To the best of my knowledge, you're confused about what you're looking at. The EEC connector is a big like 60-pin thing that plugs into the computer down on the drivers side. Do you mean the EEC Relay?
Old Jul 20, 2021 | 09:01 PM
xr4000's Avatar
xr4000
Yep sorry EEC relay
Old Jul 21, 2021 | 11:08 AM
subford's Avatar
subford
I would replace that EEC Power relay socket with a newer stile Bosch type relay and socket.
Attachment 279621
Old May 16, 2025 | 08:05 PM
Klaytenzinnn's Avatar
Klaytenzinnn
4th Gear
I believe i am having an issue with my eec relay aswell. 1990 ford f250 5.8 v8. I have it located, but i cannot seem to find anywhere that sells them.
chase61
17
Nov 19, 2011 06:54 PM
usc45cal
Oct 27, 2010 05:20 PM
wroseland
Apr 6, 2008 10:33 PM
Cocoagriz
1983 - 2012 Ranger & B-Series
Mar 20, 2006 12:30 PM
