6.0 Leaker issue, Please help.
Old Mar 31, 2025 | 10:55 AM
Packard V8's Avatar
Packard V8
Originally Posted by Byrd.Dog
I'd go with a new Motorcraft oil filter & cap. Looks like you've got the taller aftermarket one on there now, which would be consistent with Wix. If you use an aftermarket cap with an OEM filter it can cause oil supply issues...
For true. I learned the hard way, use the cap which matches the filter. In sixty-seven years of changing oil, this is the first time I've run across name brand aftermarket oil filters being sufficiently non-compliant to cause major problems. WTF???
jack vines
Old Mar 31, 2025 | 02:01 PM
Excurvelle's Avatar
Excurvelle
jack vines
6.0L like OEM parts, cap and filter should definitely be OEM, the reason being the check valve in the bottom of the oil filter housing may stay open causing a lack of filtration.
Old May 1, 2025 | 08:51 PM
GunSlinger66's Avatar
GunSlinger66
Trailering
Originally Posted by Toreador_Diesel
In that case you definitely have a 2005 engine. Mine was built probably a few days before yours and has a 2005 Engine.
Buy yourself a STC fitting kit from a Ford Dealer. If your EGR cooler is still present, you'll need an EGR install kit too to make sure you don't have any leaks.
I had a couple hours to charge up the batteries and get into this again. Attached is a photo of the CTS during cranking, it took 13-17 seconds to show low oil pressure on the dash gauge… Again any input is appreciated
Old May 2, 2025 | 10:50 PM
2004 F450's Avatar
2004 F450
Battery voltage is way to low causing slow crankshaft RPM. Either your batteries are shot or your not charging them long enough.
Old May 3, 2025 | 09:26 PM
BLADE35's Avatar
BLADE35
^^^Iirc you don’t want any voltage below 9 volt 8.7 too low
clean cables and have batts load test
GunSlinger66
Mar 24, 2025 04:58 PM
Frank M. Wood
Dec 18, 2019 02:27 PM
MeByte
Nov 28, 2017 04:55 PM
Axle rose
Jan 9, 2017 06:44 PM
Jesse Ratliff
Dec 1, 2015 10:20 AM
