Oil Pressure issue
Old Nov 30, 2015 | 07:25 PM
Jesse Ratliff's Avatar
Jesse Ratliff
Oil Pressure issue
I have never had problem with my 6.0 then Tuesday 2 weeks ago she would not start she would crank but wouldn't fire up. I had it towed and the shop says that there isn't enough oil pressure to kick on the injectors they have been tearing apart the engine since then and have not found the component causing the issue any help you all can off I would greatly appreciate.
Old Nov 30, 2015 | 07:54 PM
Jeremy05's Avatar
Jeremy05
Have they verified you have low pressure oil pressure, or base engine oil pressure? What year 6.0? Did it die while running or you just shut if off one night and it would start again?
Old Nov 30, 2015 | 08:06 PM
Jesse Ratliff
It is a 2006 with about 155,000 miles and I turned it off came out the next day and it wouldn't start.
Old Nov 30, 2015 | 08:08 PM
Jeremy05's Avatar
Jeremy05
Ok that helps a bunch. Have they checked the stc fitting?
Old Nov 30, 2015 | 08:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Take it to a different shop. The HPO leak can found in less than 15 minutes with proper knowledge.
Josh
Old Dec 1, 2015 | 10:20 AM
navistarnut's Avatar
navistarnut
Josh
Bingo Josh......I cringe when I read posts like this, gives me visions of a $$$ meter that keeps climbing with no real results. The shop knows little from what the OP says if they have been tearing into the engine and don't know why.
I would go and get that truck as fast as I can, find a reputable shop that knows the 6.0....the towing bill will pay for itself in an hour.
1960Fc170
Apr 9, 2019 05:52 AM
macequip
Jan 23, 2011 11:21 AM
pintoches
Dec 3, 2010 02:47 PM
jinxie
Feb 19, 2010 08:16 PM
