E4OD shift point change
Old Mar 22, 2025 | 04:27 PM
junkyardjeff's Avatar
junkyardjeff
After a highway trip today third gear decided to start engaging around 45 so I limped it home,changed the TPS since I had a 95 that started shifting funky with that going bad but no change. Did drive it down the highway and it went into overdrive so it looks like nothing mechanical and when I hit the switch to turn off overdrive it knocked it out of third so does this sound like something with the solenoid pack in the trans going bad..
Old Mar 22, 2025 | 04:30 PM
junkyardjeff
Forgot to add 89 F 250 with about 130,000 miles and fluid not burnt.
Old Mar 22, 2025 | 08:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What codes are stored in the PCM? Here's how to read them: www.troublecodes.net/ford
Old Mar 23, 2025 | 11:19 AM
junkyardjeff
Found two codes relating to trans 59 low fuel pump ck open/2-3 shift error 62 converter clutch slip/ 3-2-4-3 Sea foam fixed the slip and fuel pressure is 35 running
Old Mar 30, 2025 | 02:33 PM
junkyardjeff
Going to replace the shift solenoid pack.
Old Mar 30, 2025 | 06:16 PM
Mark Kovalsky
Why are you going to replace the shift solenoid pack?
Old Mar 30, 2025 | 07:51 PM
junkyardjeff
It goes into every gear so its not mechanical and must be electrical,also when I turn the o/d off it will not go into third so it looks like to me the solenoid pack has shorted.
Old Mar 31, 2025 | 06:26 AM
Mark Kovalsky
If the solenoid body has shorted there will be codes set for electrical issues. Are there?
Old Mar 31, 2025 | 04:47 PM
junkyardjeff
Yes there are codes
Old Mar 31, 2025 | 05:10 PM
Mark Kovalsky
Then either you have a solenoid problem or a wiring problem.
Old Mar 31, 2025 | 07:08 PM
junkyardjeff
I inspected the harness for critter damage and nothing.
Old Mar 31, 2025 | 08:17 PM
Mark Kovalsky
If you didn't check the circuits for continuity, short to ground, and short to power, you were just wasting your time looking at the wiring.
Old Apr 2, 2025 | 07:16 PM
zzyzxpat's Avatar
zzyzxpat
If you have a code 62, it's coming out, no simple fix.
bigcrunch
Feb 10, 2024 08:33 AM
Ethanskok
1997 - 2003 F150
Nov 22, 2019 08:35 PM
TripXAnarchy99
22
Jul 2, 2010 03:13 PM
StangMan
Feb 9, 2005 03:35 AM
