My junk yard truck must have gone skidding down the road on the rear brake backing plate, its ground flat a bit. What years would be the same so I can put up a wanted ad. Manual adjusters, 9" ford rear, drivers side rear, 1961 f100, thanks
You may also want to post the size drum / shoes because I dont know if they have different sizes for your years of truck.
I say this because my 81 F100's had 2 different sizes and I would hate to have you get the wrong size.
Dave ----
Clean that thing up somewhere on there is a Bendix number. You can use that to search for one. I think 61-67 are the same, 68 is different because of wider rear shoes.
Bendix # 305503 L , Couldn't find a bendix application chart, and not much shows up on a search. One old FTE thread came up, a guy with a 64 factory 4x4 had the same problem but thread ended with no info. Now that its off, I see I could weld it up, and, the shoe pads are worn badly too.
Could weld them up too, but really would just like a better one. Looks like grandma drove her service truck more than just to church on Sunday.
