Aux switch wiring question.
I’ve used a harness between the factory and head lights to wire in the DRL and turn signals lights and currently have it hooked up with the harness it came with (so right now the DRL and turn signals work as intended) now I want the actual off road function to connect to the uplifter switch. But I figure if I disconnect from the battery directly to the uplifter then the DRL and turn signals will not work unless the lights are turned on. Aux beam customer service sucks. Pretty sure they are in china. Not sure but the lights look great. Here is the wiring diagram that came with the lights. Anyone able to help me out? Thank you
