Running lights
Old Jun 7, 2020 | 08:17 PM
rbr658's Avatar
rbr658
Running lights
49 F1. When I pull headlight switch half out I have running lights in front but not rear. Tail lights work in all other functions. What are we missing here?
Old Jun 7, 2020 | 08:48 PM
FortyNiner's Avatar
FortyNiner
Have you checked the wiring against the wiring diagram?
Is there a turn signal unit on the truck?
Old Jun 7, 2020 | 09:17 PM
rbr658's Avatar
rbr658
yes on wiring diagram. Yes there is an after market turn signal unit with emergency flasher which works however flashers only work with ignition switch on. Shouldn't it work without ignition on if stranded?
Old Jun 7, 2020 | 09:23 PM
Mixer man's Avatar
Mixer man
By "running lights" do you mean parking lights? That would be the first detent in the switch, and is for the front parking lights only, assuming you have the stock headlight switch and it's wired correctly. The second detent (full out) turns off the parking lights and powers up the headlights, dash lights, and taillights.
Old Jun 7, 2020 | 09:30 PM
rbr658's Avatar
rbr658
Park lights
Exactly what I meant. Your description is exactly how mine are working so good to know we didn't miss something. Thanks for your quick help
Old Jun 8, 2020 | 05:45 AM
FortyNiner's Avatar
FortyNiner
To clarify, the four way flashers only work with the ignition on. Do the turn signals also need the ignition on to work?
The turn signal units I've installed were always hot and didn't need the ignition switch to be on.
Old Jun 8, 2020 | 09:51 AM
Mixer man's Avatar
Mixer man
Four-way flashers are usually on a dedicated circuit using a separate flasher unit, operating with the ignition switch off. Regular turn signals require the ignition switch to be on.
sunbelt57
17
Oct 31, 2018 05:59 PM
B-Rad31302
Nov 10, 2015 02:04 PM
JoeVB
Aug 8, 2006 08:07 PM
Knighticus
1983 - 2012 Ranger & B-Series
Apr 17, 2003 10:53 PM
