Clearance lights
Old Mar 19, 2025 | 12:24 PM
HRTKD's Avatar
HRTKD
Originally Posted by CR172
And then you have a dark dash because it switches to the night view.
I guess I just need to figure out which path to take. Obviously having just one screen would be ideal Has anyone used one of these? 7 pin adapter
That would probably work. Kind of expensive for something that probably takes power from the 12v battery charge circuit and crosses it over to the clearance light circuit.
You could do the same thing at the point where your 7-pin cable terminates at the trailer.
Old Mar 19, 2025 | 01:17 PM
CR172's Avatar
CR172
I'm sure there is more to it than just a jumper wire. Anyway I know it's more work for me but I believe the factory wired setup using the factory screen is the way I want to go. No extra screen on the dash along with a power cable plugging in the cigarette lighter socket on the dash and I don't have to mess with the headlight switch every time we stop. Plus I found the factory setup for about the same price as the Haloview and over $200 less than the Furrion setup I'm returning.
I like to keep things as OEM looking as possible as far as things like this. Wait till you see my air tank connection......
Old Mar 19, 2025 | 07:18 PM
CR172's Avatar
CR172
Originally Posted by MKrenn
If you use the factory trailer camera system, you will have to run the camera wire all the way from the front of your 5th wheel all the way to where you mount the camera. I elected to go with a wireless camera and use a transmitter/receiver to get the camera views to my main screen in my truck. I can post the link that explains how I did this and it was way cheaper than buying a OEM trailer camera.
PM sent.
Old Mar 20, 2025 | 05:39 AM
Bugzilla46310's Avatar
Bugzilla46310
All my trailer lights come on when my truck running lights are on and when my headlights are on.
Old Mar 20, 2025 | 12:36 PM
MKrenn's Avatar
MKrenn
Originally Posted by bpounds
There are pros and cons to each.
The main pro for the Ford camera is that it displays on the main dash stack. And it is a large display. Cons are that you have to run a wire to the rear, the system is expensive, and to be honest the camera control is annoying. It is constantly changing when you shift into reverse, which is when you want the trailer camera. They should change it so that, if a trailer is connected, and if a trailer camera exists, it switches to that camera instead of the tailgate, which is obviously useless at that point.
Pros for the wireless are obvious, no wiring. Cons are having another gizmo on your dash, the display is always going to be smaller, and if you want them to work you have to either run with headlights/clearance lights turned on (what most people do) or run separate power wires.
Personally I'm glad to have the built-in Ford trailer camera. But that Haloview system with trailer side marker cameras is really nice too. They just keep improving it. I think they can even offer a TPMS integration as well as dash cam.
Pro tip: You can get your headlights/clearance lights to always be on by tossing a hat or something over the sunload sensor on your dash. Truck will think it is dark. And it holds that over restarts too.
No gizmo on my dash. As I mentioned, I use the factory wiring in front of my camper. That's connected to a receiver. That receiver receives the rear camper camera video via a transmitter. I can post the link to this if anyone needs it.
Old Mar 20, 2025 | 12:42 PM
CR172's Avatar
CR172
The more I think it the more I'm not going to do anything but get the he** out of this *****hole country it has become.....
Go ahead, ban me.....
Old Mar 20, 2025 | 12:48 PM
MKrenn's Avatar
MKrenn
Bill, I sent you a PM. Holler if you have any more questions. Like I said, this is a great alternative to running a wire all the way to the rear of the camper.
We won't ban you.....
Old Mar 20, 2025 | 01:33 PM
CR172's Avatar
CR172
I don't see anything in my inbox...
Old Mar 21, 2025 | 02:39 PM
MKrenn's Avatar
MKrenn
Resent just now.
74 F250
May 14, 2021 10:00 PM
dh1200
Jul 23, 2016 04:37 AM
Force21
Aug 11, 2013 09:01 PM
comertrucks
Nov 16, 2005 01:22 AM
