Caster Shim Issue?
Old Mar 13, 2025 | 06:33 PM
Danale147's Avatar
Danale147
4th Gear
Caster Shim Issue?
Hey guys, new to the forum and looking for some help.
Just installed a set of Carli caster shims on my 2024 F250 Lariat and I've started to notice some vibration/humming as I get up to highway speeds and rattling clunking at lower speeds.
can the shims cause this, or am i chasing the wrong thing? Anyone have similar issues? I cant find much on a general search, but did find a YouTube that mentions something close to.it.
Old Mar 13, 2025 | 07:19 PM
IADiver's Avatar
IADiver
There was a thread on here about the shims changing geometry on 24+ causing that.
Old Mar 13, 2025 | 07:52 PM
Danale147's Avatar
Danale147
4th Gear
I'm curious if it has to do with the "dummy" hubs on the passenger and causing a vibration/noise, but haven't found much yet.
next step.is going to be replacing the hub with a auto locking version as they used to come from factory
Old Mar 14, 2025 | 05:03 PM
willynilly's Avatar
willynilly
why did you put shims in the first place ?
Old Mar 14, 2025 | 05:41 PM
Tsax6010's Avatar
Tsax6010
There is an SSM from Ford specifically for the dummy hub issues. Here is the original bulletin text:
https://www.tsbsearch.com/Ford/SSM52423
52423 is reported as being superceded by ssm 53231 now.
There are some good threads here on the topic
https://www.ford-trucks.com/forums/1778758-new-ssm-for-front-right-hub-fix-2.html
https://www.ford-trucks.com/forums/1...-question.html
Old Mar 14, 2025 | 08:22 PM
Danale147's Avatar
Danale147
4th Gear
Thanks for the input guys.
Today I swapped out the dummy hub with an auto locking and it immediately remedied the issue. Final step is running the new vacuum lines where Ford didn't install them on Feb 2024 build dates and after.
Hopefully this can help someone else in the same spot
Old Mar 17, 2025 | 10:05 AM
Seanzy310's Avatar
Seanzy310
2nd Gear
I am curious what degree caster shim did you install? Carli put out the article I attached below mentioning that the 2024+ models are limited to a 1 degree shim otherwise you will experience a grinding noise. The dummy hub is the other common culprit. https://www.carlisuspension.com/23-s...gMd7L58-hoA-Uh
BrandonF15005
Nov 20, 2016 06:59 AM
KTim
2004 - 2008 F150
Aug 21, 2007 06:31 AM
joe martin
2004 - 2008 F150
365
Feb 28, 2006 12:59 PM
ecjfam
2004 - 2008 F150
39
Aug 11, 2005 03:08 PM
JS 1721
2004 - 2008 F150
Oct 31, 2004 11:21 AM
