I'm looking for a new radiator to replace my worn out super cooling one in my 79 F250 460/c6. As i'm living in the netherlands, Rockauto would be my best option. Which radiator would be a good choice? and what should i look for?
There are a few different options regarding dimensions and how many rows inside. Since you have a 460 you'll probably have the biggest option for a radiator that was offered in these trucks.
Take some measurements of original radiator and the radiator support and try to match those to what you see on rock auto. You want at least a 3 row of you can't find a 4 row in the right size.
I didn't like rock auto's options, as I recall their options were mostly aluminum with plastic tanks which I'm not of fan of and are prone to leaking. I ended up using summit racing since they have all aluminum options as does bronco graveyard, but with you being overseas shipping might be an issue you would have to check into.
When originality isn't an issue I've been using the aluminum plastic radiators. I think my oldest one is about 10 years old now and no problems. when you lift the hood you hardly notice it's not original since that's what most new vehicles come with. the solid aluminum jumps at you because it looks 100% aftermarket and cheesy in my opinion.
I agree on that looks aspect, I'm going to paint the tanks on mine flat black before it goes in the truck, otherwise they do stick out like a store thumb and look weird. Would have preferred just having my original repaired but there isn't a radiator shop within a 100 miles of me anymore.
Glad you had luck with the plastic tank version, when I managed a parts store years ago those things were returned a lot due to leaking so I've always stayed away from them.
I've had no problems, the brand may make a difference. I assume they're all made in China by a few comanies. probably the same companies that make them for the auto industry.
There are some full copper repops made, not cheap but they seem okay. if cost isn't a factor that would be my first choice if you didn't have a core to rebuild.
You're right on the radiator shops, they're going the way of the buffalo hunter.
Not sure if you have any radiator repair shops there. New cores are available and you can have your original re-cored. In your situation if have a capable shop in your area that can do the work, then they have to stand behind it if there is a problem. If you have a radiator shipped from US and there is an issue with it, you are stuck dealing with return shipping, replacement which can be a mess.
Otherwise looking at RockAuto I'd go with the Spectra Premium CU847 Brass tanks and copper 4 row core.
Do you know Itchy boots?
We do have repair shops over here. They charged me 1100 euro for a new core. Seemed a bit steep for only a new core while a full alluminum on rockauto would cost me around 500 euro shipped.
How is it possible i'm unable to find that CU847 when entering my engine type and everything?
I am replacing my 1976 F250 360 radiator with one from Champion (https://www.championradiators.com). Ordered the wrong one (two different mount options, of course I chose the incorrect one). When I called and spoke with George, he could not have been more helpful. Suggest giving him a call. +1 714-974-1650
I agree .... etc ....
I had a 2003 Subaru I fixed after a minor wreck (prior owner let her insurance lapse and just gave a wrecker operator her title), and I put a new radiator in, it was plastic tanks that were attached to an aluminum core via crimping with a seal between. The new radiator started leaking at the seam one cold day, I contacted the supplier, was sent a new "same" radiator. A day came that I was gonna swap, but after pulling the leaky one out, I took a pair of channel locks, set them to close just tight enough to tighten the crimp a hair, went over both top and lower crimps, and put it back in for trial. It never leaked again. I eventually sold the car and included the new radiator still in it's box.
I'd run one in my '77 if needed (as it may be in 2025). Every other vehicle here has one now.
I forget, is it better to ground the aluminum core, or not, or do it matter?
I've heard that is recommended. Given that it is bolted to a metal radiator support that is bolted to the frame I am not sure it is absolutely needed, but ground straps are cheap and it doesn't hurt anything to add one.
When the aluminum replacement I bought goes in the truck I will be swapping out the drain valve for a small sacrificial anode rod, just like what you use in a home or travel trailer/5th wheel tank water heater. You cannot eliminate galvanic corrosion but you can mitigate its effects by using sacrificial metal such as anode rods. Ocean going vessels have zinc anodes bolted to the hull for the same purpose.
I think proper maintenance/replacement of the coolant and using distilled water is more important than grounds and sacrificial anodes.
