WIRING QUESTION
Old Mar 12, 2025 | 02:53 PM
Albeix's Avatar
Albeix
WIRING QUESTION
I am testing the wiring harness lighting circuit prior to reinstalling the radiator support. When I meter the headlight socket between the black ground wire and the respective high and low beam pin I am seeing 12v on Hi-beam pin and 11.5V(ish) on the low beam pin. plugging in a known good headlight produces no light at all on either side. Additionally the only dash light I am seeing is a dim left turn indicator. The dim turn light indicator is a tell tale sign of a bad or missing ground resulting in back feeding by some mysterious path. So my question is where are the wiring harness grounds typically physically located on the truck. There is no lighting in the back end either.
Anyone have any insight??
Old Mar 12, 2025 | 06:59 PM
dlburch's Avatar
dlburch
the lighting circuit grounds connect to the radiator support. Where are the ground wires currently connected? sounds like your radiator support isn't installed yet? if that is the case, simply hook the ground wires directly to the negative battery post for testing the wiring itself...
Old Mar 12, 2025 | 07:14 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Did you turn (rotate) your head light switch fully counterclockwise, to turn your dash lights up to full bright? If you go to the bump that is full bright on the dash lights, past the "bump" you turn on your dome light with the doors closed.
Old Mar 12, 2025 | 08:27 PM
tbear853's Avatar
tbear853
X2, sounds like you using a probe test light and if you clip that ground wire clip to the battery neg, you'll get full battery volts probing the head light socket .... but that known headlight is grounded through the harnes to the rad support which has no good ground unless mounted.
12v or 11.5V(ish) are themselves low for a good battery.
Old Mar 13, 2025 | 07:13 AM
Albeix's Avatar
Albeix
YEs With help from my buddy who is a trained electronics technician I have determined that I spent the entire day chasing a "Phantom Ground" situation. Live and learn. Good thing my labour rate is only three square meals a day from the Missus.
rubble461
May 11, 2021 08:04 AM
mcmurm
Feb 15, 2021 07:40 PM
RTennant71
Sep 15, 2011 06:12 PM
Douglas Walker
Mar 20, 2005 05:37 PM
eandaauto
Aug 1, 2004 06:12 AM
