Sponsored by: Real Truck
No sure
Old Mar 11, 2025 | 11:06 AM
alicejoe1!'s Avatar
alicejoe1!
No sure
Replaced Hpop fixed that problem turbo was not working took 1 off parts truck checked and cleaned it put it on had good boost blew off pipe on low passenger side cleaned it up pot it back took test drive hits 3000rpm cuts out still running just drops out only at wot ease into it shifts at 3000 RPM all the way through not sure what’s going on on way home truck died minute later started up then it died while it’s dead starter won’t crank but have all bills and whistles on dash OBD won’t link up with ECU came out this morning Nothing won’t crank starter is fine no cycling through injectors swapped out ECU same thing don’t know where to turn. I need help please
Fordf1501993
Apr 21, 2023 11:00 AM
jasoncw
Apr 20, 2022 10:19 AM
427 fordman
86
Sep 11, 2014 04:25 PM
Crazyotto1
Nov 4, 2013 07:52 AM
baker1983
Mar 17, 2012 06:58 PM
