66 firewal insulation/carpet install question
Old Mar 9, 2025 | 09:40 PM
66with352's Avatar
66with352
Looking to install my firewall insulation so I can then begin installing heaterbox, pedals, wiring etc. My question is, can I install firewall insulation and then slide carpet up under it or does carpet need to be put down first? I just don't want to put everything in and then have to pull it back out to lay carpet. Thanks
Old Mar 13, 2025 | 06:50 AM
66with352's Avatar
66with352
Rephrasing the question....How far up firewall does carpet go on 66 F100. Does it stop at floorplan/firewall seem or does it actually extend up higher onto firewall? Anyone??
Old Mar 13, 2025 | 07:34 AM
1966F100SC's Avatar
1966F100SC
The carpet rises about an inch above where the gas pedal mounts. I would lay carpet first
Old Mar 13, 2025 | 09:16 AM
TA455HO's Avatar
TA455HO
Lead Gopher
You can do them in either order. Easy to tuck the carpet under the 1 inch of the firewall insulation as you pull it into place. That's how they would have done it at the factory - although only certain trucks got carpet and all others got a rubber floor mat. Either way the firewall insulation was installed first.
Old Mar 13, 2025 | 06:34 PM
53deere's Avatar
53deere
The carpet was one of the last things to go in my truck.
Old Mar 14, 2025 | 11:24 AM
skidoorulz's Avatar
skidoorulz
I put the firewall pad in before anything and did everything else in the cab. Carpet and then seat was the last two things installed
Old Mar 15, 2025 | 07:21 PM
66with352's Avatar
66with352
Thanks for the info - Finished Dash and firewall insulation today - Took forever to trim and line up firewall insulation.
Old Mar 17, 2025 | 12:27 PM
cmjacko's Avatar
cmjacko
Hey 66, what firewall pad did you use?
Old Mar 17, 2025 | 02:32 PM
66with352's Avatar
66with352
This is like the original cardboard with insulation on the back. needed to trim some to fit so holes lined up. also has the sewn in rubber on bottom
Old Mar 17, 2025 | 02:35 PM
cmjacko's Avatar
cmjacko
Nice. Thank you!
RGPolo
Sep 19, 2023 09:24 AM
NotaRaptor
2015 - 2020 F150
Oct 9, 2021 08:35 AM
ERXKEEL
Aug 9, 2010 01:21 PM
saggys
Modular V10 (6.8l)
Mar 1, 2009 12:44 PM
