'22 10 speed acting up
Old Mar 9, 2025 | 04:35 AM
Rygar's Avatar
Rygar
Hi Gang, I have a '22 f-350 6.2, reg cab, srw, f-350. recieved in spring '23. 9.5 V plow, 2.2 yard sander in back. Plowing this winter and all was well... Recently I realized the truck is starting off from reversing into 2nd gear, starting a push underpowered then shifting to third and basically running out of power bogging under the load... and unless your putting the pedal down substantially, it doesn't want to downshift back to 2nd... when it does, it goes back to first... leaving you overpowered and spinning out in the middle of a push... The back and forth of clearing a parking lot, I notice it sometimes goes to 1st, other times 2nd... thinking perhaps I'm not coming to a full stop between directions, I made sure I was stopped before shifting... still many times 2nd was the starting gear. I have tried in all different driving mode's and it still does it... and the next time it won't.. Once started forward in 2nd, I have shifted to neutral and back into drive, it then goes into first gear..... another point to bring up, is the truck just seems lazy out on the highway, not having any zip, it just doesn't want to respond when kicking it down to accelerate, and seems to just want to lumber along in which ever gear it has found..... I brought it up with my dealership service, who said disconnect the batteries for a night to reset the adaptive learning... I used a pretty high quality scanner to go in and shut it off..... which seemed to correct it. but an hour later I was back to the 2nd gear starts. It is going in to the dealer at some point, we have just been to busy and need the truck... Wondering if others have encountered this when plowing???
Thanks
Old Mar 9, 2025 | 08:35 AM
OBS460's Avatar
OBS460
A 10spd transmission is a terrible idea when using a truck to plow. The trans has an adaptive learning and when you areploqing and only using 1-3rd gear then want to drive it at full speed on the interstate or even through town I would expect it ro have issues. It won't ever know what you are asking of it.
Old Mar 9, 2025 | 08:56 AM
GAZZILLA's Avatar
GAZZILLA
Maybe try going from reverse to manual instead of drive when plowing to get it into 1st gear.
Old Mar 9, 2025 | 10:23 PM
2021F350's Avatar
2021F350
I would use the manual mode in your situation... May be a bit of a PITA but at least it would be in the gear you want it to be....
Old Mar 14, 2025 | 12:01 PM
nimble.srad's Avatar
nimble.srad
Thanks
ah yes the i famous CDF hub TSB if you have a warranty u really recommend going to the dealer probably needs and overhaul.
Old Mar 14, 2025 | 01:01 PM
bigwin56f100's Avatar
bigwin56f100
the 2022's already have the updated drum
Old Mar 14, 2025 | 01:07 PM
WXboy's Avatar
WXboy
A 10 speed with shifting problems? NO WAY!!
Old Mar 14, 2025 | 01:43 PM
bigwin56f100
speak for yourself, mine has been fantastic. Put it in gear and push the pedal on the right and forget about it.
Old Mar 14, 2025 | 02:11 PM
twobelugas's Avatar
twobelugas
There was an other bulletin that covered 10r140s in diesel trucks made up to mid may 2022. It said it was for diesels but no one knows exactly how the gas 10R transmissions differs over time with the diesel
https://www.ford-trucks.com/forums/1...-noise-24.html
Old Mar 15, 2025 | 09:48 AM
bigwin56f100
I did some reading but I didn't see anything about a drum replacement only programing
sanjee4321
5.0L Coyote
Sep 15, 2025 11:12 PM
Nabors
Oct 3, 2015 08:44 AM
birdseye418
2009 - 2014 F150
Jul 8, 2012 08:26 PM
excoelis
2009 - 2014 F150
23
May 23, 2010 07:19 PM
joshsombo
Feb 14, 2006 12:32 AM
