2017 Spacer Set Up
Old Mar 3, 2025 | 12:09 AM
gcraver7's Avatar
gcraver7
6th Gear
2017 Spacer Set Up
Hey yall I’ve got a 2017 f250 and I’m looking to buy spacers for it. It is on 2” readylift level kit and 37x12.5x20 trail graps. I want it to have a more aggressive stance than it does now. Can anybody that has the same set up with spacers show me some pictures as some inspiration? Thanks
Old Mar 3, 2025 | 05:18 AM
torq'ta 5 8's Avatar
torq'ta 5 8
You want to see where it rubs on radius arm with no spacer, and then where it rubs on the fender by the door, with spacer, son's '22 has 3.5" leveling kit and it rubs, 37(Nitto mud graps) on fender.
Old Mar 3, 2025 | 07:48 AM
gcraver7's Avatar
gcraver7
6th Gear
Mine does rub but only on the upper control arm at full right. Adding spacers would only lessen the rub I would think. I’m just looking for pictures of trucks as inspiration.
Old Mar 3, 2025 | 09:19 AM
4wd6.7L's Avatar
4wd6.7L
You're talking wheel spacers?
Old Mar 3, 2025 | 09:22 AM
gcraver7's Avatar
gcraver7
6th Gear
Correct
Old Mar 3, 2025 | 11:21 AM
BDWSD22's Avatar
BDWSD22
Spacers are never as strong nor as stable as the OEM offset. I'm just saying. Here is how I use mine.
I ordered two sets of 1/2" aluminum spacers to use with my OEM aluminum wheels. There isn't much stud threads left, especially on the front, so that combo is no good. I do however use them on the rear with only the OEM steel wheels. This allows the F-250 center caps to clip onto my F-350.
Old Mar 3, 2025 | 05:41 PM
torq'ta 5 8
Aight! My son's 22 King Ranch, rubbed on radius arm, at full turn, even with 3 1/2" level kit, put 1" spacers on rub stopped on radius arm, and went to the fender by the door, rubbing on both sides.
Old Mar 3, 2025 | 06:07 PM
torq'ta 5 8
Originally Posted by BDWSD22
Spacers There isn't much stud threads left, especially on the front.
??Hmmm, my son's spacers have studs, not just a spacer that causes you to lose, threads? see pic
Old Mar 3, 2025 | 06:16 PM
4wd6.7L's Avatar
4wd6.7L
A 1/2" spacer is a slip on spacer, leaving a limited amount of threads. I think a 3/8" slip on is about as thick as I would consider going. That's probably also the sweet spot, keeping the tires off the radius arms and off the fender.
The bolt on spacers like your son used require cutting of the factory studs for spacers below a certain thickness. If his are 1" I bet he had to cut his studs down. To avoid that I think it requires something closer to 2"(?).
Old Mar 3, 2025 | 06:45 PM
BDWSD22's Avatar
BDWSD22
With all that rubbing going on I don't know if it's NASCAR or something erotic going down, LMAO!
Old Mar 3, 2025 | 07:09 PM
torq'ta 5 8
I was wrong his are 2", and we didnt cut the axle studs any, couldn't use regular lug wrench too deep in.
@@BDWSD22 well you know. LMAO!
Rwhjr
Jul 9, 2021 07:53 PM
Caspero
Mar 19, 2019 04:52 PM
tojoski
73
Feb 15, 2017 08:14 PM
BIGTRUCKBIGRV
6.7L Power Stroke Diesel
22
Jun 24, 2013 10:11 PM
JB666Rock
Dec 1, 2005 08:50 PM
