Sponsored by: Real Truck
Turn signal problems
Old Mar 2, 2025 | 01:27 PM
D Craig's Avatar
D Craig
Got an 06 6.0 with blinkers that don’t work. Hazards work however the left and right turn signals do not. I swapped the relay under the dash behind the AC controls and the trailer tow relays under the hood as well as checked all fuses none are blown. Any ideas?? Thanks.
Old Mar 2, 2025 | 02:32 PM
marksman76's Avatar
marksman76
Disconnect the trailer harness if you have one by rear bumper.,
Also there should be two flasher relays.
One for hazards, and one for turn signals.
Likely different specifications.
Old Mar 3, 2025 | 07:45 AM
lshort's Avatar
lshort
These trucks use 1 flasher that takes care of turn signals and hazards,could be the problem, or the multi function switch.
Old Mar 5, 2025 | 12:17 PM
D Craig's Avatar
D Craig
where is the multi functional switch? I unplugged the trailer harness no change still no turn signals.
Old Mar 5, 2025 | 12:38 PM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
Multifunction switch is the actual turn signal switch.
-Steve
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Jamon Norton
Mar 27, 2024 05:02 PM
Dos Monitos
6.7L Power Stroke Diesel
15
May 23, 2018 11:41 AM
jph9475
1997 - 2003 F150
Mar 22, 2013 09:16 AM
Kyle 4X4 4life
May 22, 2011 12:39 PM
mason
Dec 12, 2002 12:39 PM
