Turn Signal Problem
Old Dec 26, 2001 | 01:16 PM
mason's Avatar
mason
Post Turn Signal Problem
I've got a '95 Explorer XLT with a strange turn signal problem that I can't solve. Recently, when using the right turn signal the flasher relay under the dash will "buzz" and the turn signal will not work. This only happens when using the right turn signal in the full on position. It works fine in the half position that is used for changing lanes. The left turn signal continues to work as it is supposed to. So far, I have replaced all the turn signal bulbs on the right side, the flasher relay under the dash and the right turn signal relay that is part of the towing package and is located by the battery. I have also checked the wiring around the bulbs to make sure there were no apparent problems. I'm at wit's end on this. Any help will be greatly appreciated.
Old Dec 26, 2001 | 08:47 PM
nitro94's Avatar
nitro94
Turn Signal Problem
Sounds like a muti-functon switch problem to me. I do replace a lot of these for various reasons.
Old Dec 27, 2001 | 08:02 AM
mason's Avatar
mason
Thanks, Nitro. I was afraid this might be the problem since it's probably much more expensive than the relays and bulbs. Unfortunately, you cannot return electrical parts so I was hoping to avoid replacing the switch unless I just had to. Looks like I'm off to the Ford dealer again.
Old Dec 29, 2001 | 01:31 AM
N700MS's Avatar
N700MS
Turn Signal Problem
I had the same problem with my '95 XLT about a year ago. The whole turn signal had to be replaced. I think it was just because being used so much.
N700MS
Old Dec 11, 2002 | 02:48 PM
scosee's Avatar
scosee
Turn Signal Problem
95 XLT w/ same buzz making left turns, how much for the switch?
Old Dec 12, 2002 | 07:15 AM
mason's Avatar
mason
About $55 from the dealer. Try cleaning it first by spraying electrical contact cleaner around the flasher switch on top while repeatedly pushing the switch off and on. May not work but worth a try. Be sure to disconnect the battery before doing any work on the steering column.
mason
Old Dec 12, 2002 | 12:39 PM
reberhardt's Avatar
reberhardt
Turn Signal Problem
