68 Hazard lights switch
Old Feb 26, 2025 | 03:42 PM
WDXPW's Avatar
WDXPW
I have only seen a pic of one so I dont know how it works or if it may be available NOS or good used condition my 68 is missing it and the brake light switch goes through it. Does anyone reproduce these ? Does anyone know the engineering number for one of these?
Old Feb 26, 2025 | 04:00 PM
Centennial F100's Avatar
Centennial F100
if you Google "bumpside ford emergency flasher switch" you will find some sources. LMC has them as well, if in stock. Emergency Flasher Switches - LMC Truck
Old Feb 26, 2025 | 04:29 PM
WDXPW's Avatar
WDXPW
Where was black bracket style mounted on the dash ? Also on my dash going right to left there is a cigar lighter, **** for the choke, and one more hole that is blanked off and then the steering column I saw a pic of a 68 truck recently on F book that was being called unrestored and in my blanked off spot was what looked like a period part that had a red self illuminating switch I thought it may have been factory for the emergency flashers.
Old Feb 26, 2025 | 05:01 PM
Centennial F100
The switch on my 67 is located in the glove box, top left side. Maybe someone with a 68 can chime in?
Old Feb 26, 2025 | 07:59 PM
Green72F250's Avatar
Green72F250
Here is a good thread that discusses the locations of the emergency flasher thru the bumpside years: Where is the emergency flasher switch? - The FORDification.com Forums
Old Feb 26, 2025 | 08:18 PM
WDXPW's Avatar
WDXPW
Thanks Green 72
Old Feb 26, 2025 | 09:52 PM
Green72F250
You're welcome. Glad I was able to help.
Old Feb 27, 2025 | 06:38 AM
Makeryguy's Avatar
Makeryguy
The illuminated red switch is for the cargo light on the rear of the cab if equipped. It lights the **** when on, and goes out when off.
eddie a
Jul 30, 2015 08:15 AM
rutrows
Oct 21, 2010 03:03 AM
TheTowingCowboy
Aug 31, 2009 12:15 AM
missviv2
Nov 1, 2006 12:07 PM
phmco
1997 - 2003 F150
Nov 15, 2003 07:35 PM
