If you mean is it an easy swap that just bolts in, then no, this is not the case. If you mean someone that is greatly experienced doing engine swaps, then with a whole lot of time and money this is possible. I have often said if you give me enough time and money I can put ANY engine into ANY vehicle.
It will probably cost far more than buying a 2024 F-350 with a 6.7L, but it could be done.
I need the 7.3L in my 94 swapped to my sons new ford Ranger asap. we have a blower hood ready to go, should help the fit. It already sits real low up front and high in the rear so we got that issue covered too.
