1978 - 1996 Big Bronco
Relays
Old Dec 18, 2003 | 01:41 PM
BillyBob69's Avatar
BillyBob69
OK I tried you email from both my my work address and it keeps kicking it back to me rejecting my emails as spam. (Its in spanish but I do read spanish) Now one has my (at)avanade.com and the other was (at)mms.gov (fed email), is there another that I could use?
Old Dec 18, 2003 | 01:45 PM
eriojas's Avatar
eriojas
irenenacoud(at)hotmail.com hope it works
Old Dec 19, 2003 | 11:00 AM
eriojas's Avatar
eriojas
last night dissambled transfer case motor again put selector on transfer case at 2wd and moved the motor so that it would be aligned at 2wd, everything was at 4high, put everything together tested and it worked!! my truck was stuck in 4low after a deep water adventure, and pushed the buttons an no clicking behind glove box, so the diagnosis was that the control module was the problem, tested it and everything came out right, took it to a specialist on 4x4 issues and told he had to change motor and control module, imagine the bill, so i think that if it gets stuck you have to put everything in 2wd manually and somehow everything resets itslef, or maybe it was luck, anyone i can help with this issues, im here.
Eduardo
Old Dec 21, 2003 | 08:21 PM
Black Ford XLT's Avatar
Black Ford XLT
4x 4 problems
heres more information on your 4x4 systems--its under explorer maintenance but these controllers and motors are identical to our broncos ---------read all the pages as it helped me rebuild my motor and check out my controller for 0$$$$$$ http://www.glue.umd.edu/~singletn/web/pages/tcase.html TR
Old Dec 22, 2003 | 10:22 AM
eriojas's Avatar
eriojas
well after all only 2wd and 4x4 works, 4 low does not engage, serviced the motor, any ideas?
BAD RONALD
21
Oct 25, 2017 08:45 PM
036.0stroke
May 6, 2016 02:26 AM
RabidJade
Dec 7, 2012 08:43 AM
TestDepth
Feb 25, 2007 05:49 PM
mjolly5150
All Things Towing
Sep 7, 2006 02:53 PM
