Could someone post a diagram of the location for the relay for the transfer case shift motor? I have the dash mounted 4x4 and it won't engage. I think that might be the problem.
screwy, do you have wiring diagrams from the 4x4 switch to the module and from the module to the tranfer case, from the diagram you sent seems you have good information
could not acces your email because im new, so it says when i try to access it but my email is eriojas@vector.com.mx, my truck is a 92 EB, thanks in advance
last night in desperation, took the actuator motor out, dissasembled dashboard, blew some fuses out, put the selector in the tranfer case mannually from 4 low to 4 high, tested the control module, and seems fine, in relation with the procedure posted somewhere here, 5 hours later and some cuts and bruises everything assembled push the buttons and nothing happens, must be rocket science, anyone have any suggestions, need wiring diagram, thanks
ERIOJAS & FB993....I do have the wiring diagrams for your trucks at home, and I have looked at the diagram for the 4x4 system and other stuff. I just need to set up my scanner and hope that the resolution is good enough. (Old scanner) SHould be good though. The only issue is that the email option in this forum apparently has been turned off. I saw that there was a link posted but I must of done something wrong and couldn't get it to work. Find a way for us to communicate outside of here and I can send you the schematics.
