Headlight relays
Old Apr 26, 2016 | 06:22 PM
036.0stroke's Avatar
036.0stroke
Headlight relays
Hey guys I have 2 40a relays I was going to use to make my lights brighter. Can I run both high beams on one relay and both lows on one or do I need 4 separate relays. And do you know which color wires going to the lights do what. Thanks
Old Apr 26, 2016 | 07:57 PM
HIO Silver's Avatar
HIO Silver
One 30-amp relay for the lows and one 30-amp relays for high beams.
The Math
The formula is: Watts (Power) = Volts times Amperes (Current)
60 Watts = 12 Volts X current....
Solving for current: 60 Watts/12 Volts equals 5 amps.. plus a load factor of 1.5.
Therefore, two 60-watt lamps equals 10 amps times 1.5 equals a 15-amp rating. .. but 20 amp relays aren't common so just go with one 30-amp relay and protect the circuit with a 20-amp fuse.
Get a relay with two terminal outputs, 87 and 87A. Be sure you do not opt for a "change-over" relay because only one output terminal is energized at any one time.
Let's assume you opt for 100-watt high beams:
100 Watts/12 VDC equals 8.33 amps per bulb. That's 16.66 amps total times 1.5 equals 25 amps... that's still good with a 30-amp relay. Protect the circuit with a 25-amp or 30-amp fuse.
Old Apr 26, 2016 | 08:08 PM
351Cleveland C4's Avatar
351Cleveland C4
Hio is right. You can use 2 relays. Even the single output is workable if you splice the wires together.
Old Apr 27, 2016 | 03:49 AM
GaryKip's Avatar
GaryKip
HIO, would that relay with the 87A output be the 5 blade relay?
Old Apr 27, 2016 | 08:44 AM
HIO Silver's Avatar
HIO Silver
Yes... but a 'change over relay' can also have five terminals. Verify the circuitry.
Old May 5, 2016 | 07:04 PM
036.0stroke
Okay I did the relay install and I am happy with the function but I do not like the way it looks like a mess. Any ideas on how to clean this up
Old May 5, 2016 | 07:50 PM
orich's Avatar
orich
You should have used this dual relay plug for a cleaner installation.
Less tacky looking' I have gotten a couple of these but many of the Chinese ones now have smaller ga. wires.
I think the Chinese are now selling wire by measuring the whole wires OD with insulation, not the real wire gauge size which is smaller ID.. Oh that doing business with them
Orich
Old May 5, 2016 | 07:56 PM
036.0stroke
Orich
I'm going to have to get one of those. Didn't even think about using one. I guess this helped clean it up some for now
Old May 5, 2016 | 08:06 PM
Randle's Avatar
Randle
Those dual plugs are a good idea, I'll have to remember that for the Mustang, I want to hide everything I can on it. Here is how I did the 70, placed them on the core support beside the battery, all you can see is the top of them. The 3rd one is the fog lights.
Old May 6, 2016 | 02:24 AM
GaryKip's Avatar
GaryKip
Randel, I like how you ran the starter wire thru the fender.
Old May 6, 2016 | 02:26 AM
GaryKip's Avatar
GaryKip
036.Ostroke, with the wire loom on, it doesn't look so bad.
bkuuz1
6.7L Power Stroke Diesel
Sep 17, 2017 06:48 AM
Harrier
Sep 20, 2015 08:45 PM
88dually
Feb 22, 2014 08:10 AM
FXDC4419
Mar 21, 2008 02:09 PM
cbrnflt
Electrical Systems/Wiring
Dec 24, 2006 07:22 PM
