Front sending unit
Old Feb 24, 2025 | 06:30 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Front sending unit
My front tank sending unit float has crapped out on me. I filled my front tank up yesterday and the gauge still reading empty. While the tank reads correct. I had done e-fuel not long ago and dropped both tanks but only replaced the rear sending unit because of the inaccurate readings. Should have replaced both in hind sight.
Question, does anyone know if the front sending unit can be replaced without dropping the tank? From memory, the unit sits at an angle. I was hoping that it would clear while pulling the unit out of the tank. I have a standard long bed. And I'm not interested in pulling the bed off.
Thanks.
Old Feb 24, 2025 | 07:00 PM
farmert's Avatar
farmert
I don't think the sending unit can be removed without dropping the tank, or lifting the bed.
Old Feb 26, 2025 | 10:11 PM
paddler's Avatar
paddler
I spent too much time dropping tanks... replacement tanks, leaking sender gaskets, showerheads, leaking line connectors to senders, tank selector valve. And now I have a bad sender.
If you have no lift or jack adapter to keep tank and skid plate level, a trick is to a pair use tie-down straps, one at front and one at rear. Securely connect one end of strap to frame (hook or cam loop, depending on which style of strap you use). Loop under tank or skid plate. Wrap other end around frame or driveshaft 3 or 4 times, and pull tight. You may have to work the wraps around to get them tight. When weight comes on the wraps, friction from the wraps holds them tight. Once bolts are loose, gently jiggle the loose end of the wrap, and it will slowly drop the tank or skid plate. You'll have to lower alternate straps a bit a time, and rotate the plate / tank in the cradle of the strap as it lowers. Raising is the reverse... but you have push the plate/tank up a bit then rotate and tighten the wraps. Tedious, but it lets you do the work without lift, jack, or a helper.
I don't see how you can get the sending unit out without dropping tank (easier, in my opinion) or removing bed. Sender goes straight down into tank from top, so you need enough clearance for the full length of the sender. I'm skeptical that you can leave fill and fuel lines and electrical connector attached then partially drop and rotate tank to get enough clearance. I just put tank all the way on the ground and slid it out from under the truck.
Old Feb 27, 2025 | 07:12 AM
z31freakify's Avatar
z31freakify
I removed the bed by myself but I do have a sturdy pole barn that helped me, you can also just lift the bed high enough on one side and secure it.
ag-ford-4x4
Oct 20, 2024 04:04 PM
southtexasidi
May 2, 2020 02:44 PM
jeworthington
Sep 7, 2011 08:48 AM
Rcodenewf
Nov 4, 2009 01:28 PM
