Sponsored by: Auxito
RAP module
Old Feb 24, 2025 | 12:53 PM
Carbody2's Avatar
Carbody2
3rd Gear
RAP module
1997 F150 EXTENDED CAB LARIAT AUTO TRANSMISSION
I have an interesting mess found under may dash at the RAP module. Replaced a gem module and fuse box after finding a parasitic drain and fixed the problem.
Scanned the vehicle with an Autel scanner and found no communication to the RAP module. Investigated and found the connectors had been cut and split with a jumper wire installed. This is going to fun! ordered a used RAP module to get the plugs the problem may be replacing the module. Anybody know the procedure for assigning a different/used module to the current vehicle being repaired?
Old Feb 25, 2025 | 06:54 AM
manicmechanic007's Avatar
manicmechanic007
The book has you program it using a NGS scan tool and the vin specific software off of Oasis at the dealer
You can do it using forscan if you are savvy enough
Post what year and what your trucks configuration is, (engine and trans) or you will get mostly gibberish on here
Old Feb 25, 2025 | 08:00 AM
Carbody2's Avatar
Carbody2
3rd Gear
1997 F150 Lariat 4.6 auto transmission.
What about using an AUTEL MS 906 TS?
Old Feb 25, 2025 | 09:21 AM
manicmechanic007
Not sure, never had one
Is it bidirectional?
These days that module programming is available places online
There are sure more people on here, that know more about this subject than I do, I just have a NGS from my dealer days and know it'll do it
The people on here that I read about them doing it are "not" using a factory NGS
So, that means your Autel sure might do it
I'm about to buy one of those for my Mercedes
Old Feb 25, 2025 | 11:05 AM
Carbody2's Avatar
Carbody2
3rd Gear
Yes the AUTEL is bi directional and an awesome tool.
Siscoken
Large Truck
Aug 6, 2024 10:31 AM
eagle243
2009 - 2014 F150
Apr 8, 2024 10:27 AM
Buellrider76
15
Sep 18, 2023 09:38 PM
YooperUno
1983 - 2012 Ranger & B-Series
Nov 10, 2022 12:58 PM
txazguy
6.7L Power Stroke Diesel
Mar 24, 2017 04:47 AM
