Sponsored by: Auxito
Need Help Finding Bolt....
Old Feb 24, 2025 | 05:16 AM
TWainsco97's Avatar
TWainsco97
1st Gear
I was changing my resovoir on my 1997 Ford F150 4.9L and misplaced the bolt I had (shown in picture) I've looked everywhere online for it and cannot find it for the life of me. This may turn into a junkyard run if I can't find it.
Bolt circled here, i know it tightens with a spring load mechanism.
Old Feb 25, 2025 | 06:47 AM
manicmechanic007's Avatar
manicmechanic007
That is the pressure line adapter that holds the pressure relief valve in the pump
Two different fitting sizes depending on the year and the pressure line threads
Right, the valve with the spring
You need the shorter metric one
I have a couple
They used to send two of them (1 each style) with a brand new Ford pump that cost 450
I probably have 10 of them
You might need a 3B584 seal kit to get new O-rings for the new part
PM me your address and I'll send you one if a junkyard is not close
Old Mar 1, 2025 | 03:18 PM
manicmechanic007
I found these
Yours should be the one on the left with the shorter 15/16 hex
haircutter
Jan 12, 2022 04:05 PM
oldgrayman
1947 and Older Ford Trucks
Oct 29, 2016 02:40 PM
Redneckfordf2502002
May 21, 2012 12:50 AM
Spider-Kenneth
Bronco II
Feb 1, 2012 08:05 PM
78ford351m
Jun 2, 2008 07:07 AM
