Need help Turn signal / Backup lights not functioning
Old Feb 26, 2025 | 07:22 PM
  #46
dlburch's Avatar
dlburch
when you install your new sockets, re-confirm all the grounds and bulbs...the symptoms of the turn signal indicator being on with running lights activated is a symptom of a bad ground...and one of the running lights is going back through the right blinker circuit for ground.
Old Feb 26, 2025 | 07:50 PM
  #47
77JadeF150's Avatar
77JadeF150
That makes sense. I’m going to clean each bulb and double check each ground while installing. Hopefully those efforts are fruitful. I’ll report back with findings. I pulled the LED sidemarkers out for now and replaced them with standard bulbs to eliminate them as a possible problem.
Old Mar 3, 2025 | 12:05 PM
  #48
77JadeF150's Avatar
77JadeF150
All figured out, replaced all the sockets and when investigating each one I found the culprit. While the socket looked good, almost the best of all of them. The ground pin inside the socket was rusted away mostly and was quite difficult to pull out through the rubber seal on the backside.
derkostav8
Jul 16, 2024 03:26 AM
JPecka
15
Feb 29, 2024 08:43 AM
Branden Heine
Apr 4, 2021 07:50 PM
michael69
Jul 15, 2019 10:37 AM
fordito
Mar 13, 2008 10:23 AM
