Sponsored by: Real Truck
Heat defrost vent problem
Old Feb 19, 2025 | 04:29 PM
rigid1's Avatar
rigid1
I have an 03 250 . The heat is only coming through the defrost and a small amount on the floor. I believe this is the default setting and glad I have at least this. In the past i have found a line pulled apart under the hood and fixed the problem. This time i found where the black plastic line had come apart and slip a 5/32 rubber hose across it both ways leaving plenty of over lap. It did not fix the problem. I have turned it off and on several times. It has been about a week. Once sitting at a stop sign it did vaguely start to come through the dash vents , but nothing since. It appears that everything above the box on the passenger side fender is plugged in. I can tell the know selector is working . Any suggestions as to where I might look ?
Thank you
Old Feb 19, 2025 | 04:39 PM
Old and soft's Avatar
Old and soft
You likely have a vacuum leak somewhere. Auto bubs, or any vacuum accessory cold. be leaking.
Thomas460
Nov 27, 2022 07:51 PM
WoodBoss
Mar 9, 2015 07:53 PM
cbrcassio
Apr 20, 2013 05:11 PM
s1120
Nov 14, 2006 12:06 PM
mrsuperman15
Dec 5, 2004 01:58 PM
