Hey Everyone,
2005 regular cab 4x4 STX cruise control stopped working. I changed the brake pedal switch and didn't fix it unless I got a bad one. I checked #14 fuse (redundant speed control) if it was blown but did a continuity check on the fuse and it was good.
What else is there to check?
UPDATE: Come to find out I don't have any brake lights so something else is going on. I checked the brake fuse and it's good. I'm thinking it's a brake pressure switch but I don't know where it's located. I thought it would be on the master cylinder but it's not and I don't see it in line anywhere. So I will probably create another post if I can't get the brake lights to come on. TIA
