parasitic power drain
Old Feb 18, 2025 | 09:03 PM
rich1785's Avatar
rich1785
Gentlemen,Gentlemen,
I have a parasitic drain on my 85 F350 diesel, It is outside the fuse box. At some point in the trucks life it has had: snow plow, camper and trailer wiring installed. I have removed it all since it was all rotten anyway. It is back to 99% stock wiring. I pulled all the fuses and it still drains over night. If I unbolt the + power to the glowplug relay which of course feeds the starter relay the drain stops. These are normally hot as per the wiring diagram so not sure where to go now. Any ideas?
Old Feb 18, 2025 | 10:54 PM
BigBlue2's Avatar
BigBlue2
You have two relays to check. Maybe one of them has a short to ground?
Old Feb 19, 2025 | 06:21 AM
tjc transport's Avatar
tjc transport
i ain't rite
disconnect the alternator and see if the draw goes away. also could be the voltage regulator.
Old Feb 20, 2025 | 07:49 PM
gespeter's Avatar
gespeter
You can connect a 12v tester or tail lamp-size bulb in series with the + battery cable. A drain should cause the lamp to glow. Then disconnect one thing at a time until the lamp goes out and you've found the problem. Completely disconnect one of the batteries. Disconnect positive terminal of remaining battery and insert lamp between battery and cable.
Old Feb 26, 2025 | 10:05 AM
rich1785's Avatar
rich1785
I have replaced the starter/glowplug relay recently. I pulled all the fuses and disconected the rear wire harness by the back bumper that shots off the trailer/lic. plate/blinker/rear brake/ rear park lights. No deal still has a drain.
Have not yet changed out the alternator to the 3g but plan on that when I get this figured out. How do I check the voltage regulator?
Old Feb 26, 2025 | 11:49 AM
tjc transport
i ain't rite
unplug it.
Old Feb 26, 2025 | 12:29 PM
rich1785's Avatar
rich1785
parasitic saga
ok, that clear and easy. I'm guessing it should not draw power? How do I know to replace it?
Old Feb 26, 2025 | 12:46 PM
ihc1470's Avatar
ihc1470
If you are looking for a power drain and with regulator unpluged that drain would go away then regulator would be bad. If just measuring to see what it regulates the voltage to, use a voltmeter and look for around 14.7 dc.
Old Mar 3, 2025 | 01:17 PM
rich1785's Avatar
rich1785
That was it, you win the guessing trivia game!
Thanks!
Cparrish99
2011 - 2019 Explorer
Sep 12, 2022 06:09 AM
FORD2007EXP
Jun 6, 2022 11:25 AM
jeffbradbury7
Aug 18, 2013 04:37 PM
amos truckalot
Jun 29, 2010 07:57 AM
