PLEASE HELP! I Lost Power Steering!
Old Feb 16, 2025 | 11:45 AM
DSLTRK60's Avatar
DSLTRK60
Probably lost the piston seal in the steering gear, and are blowing pressure past the piston.
Should also check the unloading valve, could be stuck open as well
Old Feb 16, 2025 | 12:18 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by Lou Braun
The electronic assist only reduces steering effort but does not remove power steering capability.
..and there's the fact that his gen did not have electronic steering assist. (That started in some configurations 2020MY)
Old Feb 16, 2025 | 01:18 PM
cpobst's Avatar
cpobst
My 2017 had adaptive steering.
Old Feb 16, 2025 | 01:19 PM
4wd6.7L's Avatar
4wd6.7L
Ok, and Adaptive steering is not electronic power steering assist. Alot of people still seem to conflate the 2 features even though they are entirely different. AS reduces steering ratio not effort, electronic steering assist reduces effort, not ratio.
Old Feb 24, 2025 | 10:38 PM
Johnbrad's Avatar
Johnbrad
1st Gear
Originally Posted by Baby John
2019 F250 FX4
Last night i turned traction control off and did a burnout on a bridge, then…cut a damn donut in a gravel road. Playing around a little. Stupid…I know…but before i even finished the complete donut, I lost all power steering. I mean nothing…nada…zilch.
Lou Ferigno couldn’t drive this thing.
What the heck happened? Is there a fuse or something that might have blown while i was horsing around
What ended up being the prothem? I'm working on a 2017 f250 king ranch has the same issue. He cut the wheel hard to spin a 180 in the snow and now it has no power steering amd thr service adaptive steering light is on. The Wheel is 90 degrees off center. He got a new steering box had me replace it no change. Can turn the wheel maybe 50 degrees either way from center fine but after that it takes two hands to pull the wheel around
Old Feb 25, 2025 | 05:29 AM
Baby John's Avatar
Baby John
it was the power steering pump. Easy repair. I was down in my back and had to hire it out to a buddy but he did it for me in a couple hours and that was stopping for a beer now and again.
we got the old pump off and i tugged on the pulley and it pulled straight out of the pump. The small shaft (maybe 1/4” - 5-16”) had snapped clean in two.
he took the cold air intake off to make it easier to get to the bolts. Think there’s four bolts. Took the bottom bolts off first while leaving the top in place to hold the pump steady and took the top bolt out last…from the top.
ford wanted over $1,000 for a new pump but i bought one from Rock Auto for $380 with the pulley already attached
you can go cheaper if you get one without the pulley but you have to have a pulley puller to get the old pulley off. I didn’t wanna risk damaging the old pulley so i bought one with a pulley already on it
Old Feb 25, 2025 | 05:35 AM
Baby John's Avatar
Baby John
If you’re in the process of working on it, you should be able to remove the serpentine belt and pull out on the pulley. Shouldn’t be able to pull it out any at all. I’d say…if you can pull it out any at all, then that shaft has broken.
but…it’s strange that you’ve got partial steering…the 50 degrees…seems to me if your issue was the pump, then you wouldn’t have any steering at all.
need to try the pull test though.
Old Feb 25, 2025 | 08:33 AM
4wd6.7L's Avatar
4wd6.7L
It sounds like you are having multiple system issues. The 90 degree off is the result of an adaptive steering fault, which makes sense since you have the error light. It's possible that whatever is causing the power steering issue, is just triggering the Adaptive steering system to go into fault mode. Hopefully after the power steering is fixed, the AS goes back to normal.
Old Feb 25, 2025 | 11:23 AM
Baby John's Avatar
Baby John
That's what I'm thinking...if his pump went bad, it may have triggered the "Service Adaptive Steering" code...but what I'm confused about is how he's able to make an "easy" turn to about 50 degrees. if his pump was bad you wouldn't even have that. Unless, perhaps there's just enough bite on that shaft where it broke to possibly spin the pump internals up to about 50 degrees.
Old Apr 11, 2026 | 12:48 AM
Wolf2017's Avatar
Wolf2017
1st Gear
what did you end up finding out with yours? I have the same issue going on right now.
Old Apr 13, 2026 | 04:17 PM
Baby John's Avatar
Baby John
Power steering pump went out on mine. Think I got a new one at Rock Auto.
Hesson81
29
Aug 11, 2021 06:11 AM
DerekP
Aug 1, 2021 03:20 PM
bjmayberry2
Jul 5, 2021 02:22 PM
