Have you run an injector buzz test? Any DTCs reported after it?
Injector Buzz test passes without a hitch, all 8 are loud and just as strong buzz as one another, no codes after buzz test. Or at all for that matter. Came in with a 1280 ICP sensor code, realized it had an aftermarket sensor in it, replaced with OEM Ford sensor from local dealer code went away and has not came back.
The voltage reading correlates with good ICP. You have sufficient pressure.
Ah so checking voltage at the ICP can tell you if it is actually seeing pressure as opposed to getting a default reading from the PCM? This is a lot easier than connecting a gauge if so.
Yes. The PCM will always report the actual voltage reading. KOEO should be in the neighborhood of 0.24 V or so at sea level. The cranking voltage needs to exceed 0.84 V (if I'm remembering correctly) for the PCM to command the IDM to fire the injectors.
Edit: A reading vastly different with KOEO generally indicates a bad sensor.
Well Pikachu, I was pretty sure getting that good voltage reading from the ICP sensor was a good indicator that we had HPO. But just to confirm I did engineer a fitting to test HPO at the ICP sensor port. Confirmed mechanically we indeed do have HPO at the rails. I will now be moving onto testing fuel pressure at the filter. Hoping to find something fueling issue related, exhausted a lot of options with that one.
Finally got around to checking fuel pressure, due to working on other cars in the shop. Tap in line about a foot after the fuel pump on the frame. right at the quick disconnect, had a solid 60psi KOEO also 60psi while cranking. i have not checked post filter yet, waiting on my fittings to get her to test at the head and the post filter port on the bowl. What other issues could i be having with this thing. Wishing i could raise the dump bed right about now to check the strainer in the tank, i removed the filter once again and found small black specs in the bottom of the bowl......
Did it randomly stop starting one day, or was it after a part was replaced?
Wouldn't be the first time in here where it ended up the stand pipe in the fuel bowl got turned and shut off fuel flow post filter during a filter change
One way to confirm fuel after the fuel bowl would be to remove a fuel rail banjo bolt
There is an 1/8" NPT plug in each head that go to the fuel rail. They're a bit fiddly to get to, but you can test fuel pressure there as well. The left head plug is at the back and is easier to get to than the right side, which is at the front. It is easier to test at the filter housing, but you can test at the heads without ordering and waiting for an ORB adapter.
Why was the PCM replaced? Do you have the one that came out just in case that becomes the last suspect?
PCM was Replaced by another shop, their estimate says had lack of communication with scanner. It still doesn't communicate with any Snap-On scanner, but Forscan on my laptop works just fine. My fitting will be here in the next 1/2 hour, so we shall see what we have post filter. I plan on testing at filter port, and both 1/8th NPT ports, just for confirmation an all ends.
Should be seeing in the neighborhood of 100PSI at the pump. The fuel bowl test ports should be around 65PSI.
I read it as he put a Tee in the line by the pump which would still have the regulator in play and same pressure. But if he dead headed it then you may be onto something.
