Adjustable Pedals HELP
Old Feb 11, 2025 | 06:03 AM
Mattv7.3's Avatar
Mattv7.3
4wd Low
02 Limited Excursion 7.3. my brake pedal no longer adjusts, the throttle moves as it should still. I have pulled the cable off of the brake pedal assembly and the cable turns, seems to be an issue in the pedal setup. I can’t find anything at all on how to repair this, i’d really like it to work again. Any insight is much appreciated.
Old Feb 11, 2025 | 03:09 PM
01__Excursion's Avatar
01__Excursion
Time to check for power at the switch, and or the plug connection to the pedal motor. If parts are needed, salvage yard, or ebay is probably you're only bet.
Old Feb 12, 2025 | 10:25 AM
Pickupmanx2's Avatar
Pickupmanx2
Could be the gearing inside the assy stripped... my ex had a bad habit in the Ex of having her foot on the brake when adjusting them.. the adj. accel pedal in my 02 F350 went out about a year ago or so, not the adjusting part, the potentiometer inside, I rplc'd it with a non-adjustable one for $160, as the adjustable pedal assy was over $800. I would take the old one out and see what you can see.. it's already broke, can't break it any more is what my dad told me growing up.
I have to say, on all the ones I've had with adj pedals, I've had to unplug the accel and move the brake towards the seat to get them more equal if that makes sense. I haven't looked to see if the non-adjusting brake pedal will bolt in place of the adjusting one... the accel pedal one does, never really notice the difference now.
Mudshovel40
May 19, 2024 10:54 PM
Pekoe56
1997 - 2003 F150
16
Sep 17, 2020 12:01 PM
brickie
Nov 17, 2009 09:58 PM
obxsurfdoggie
Aug 24, 2004 08:13 AM
straight 6's
Mar 17, 2003 08:48 PM
