Cab weight
Old Feb 10, 2025 | 08:31 PM
bobscogin's Avatar
bobscogin
Cab weight
Looking for an approximate weight of my '53 F100 cab with doors and glass installed. Also, suggestions on lift points/rigging for removing.
Old Feb 10, 2025 | 08:40 PM
56panelford's Avatar
56panelford
Don't think the cab would weigh much more than 300 -350 lbs
Old Feb 10, 2025 | 10:04 PM
Waygonner's Avatar
Waygonner
I found it much easier to lift the cab with doors off. The upper door frames can take the weight. I built a wood 4x4 attachment for my cherry picker. Have lifted with both doors on and off and I found it to be sketchy with the doors on. The cab doesn’t weigh much. It’s similar to an engine.
Old Feb 11, 2025 | 06:34 AM
M2HB's Avatar
M2HB
My family and friends lifted my 55 cab off, without the doors. It was not too heavy.
The doors themselves are not heavy, but with the latches, windows and mechanisms they start getting heavy.
If you have a complete cab with glass and doors, I would definitely use a mechanical device for lifting it.
Old Feb 11, 2025 | 09:14 AM
Doug's Messy Garage's Avatar
Doug's Messy Garage
Thanks for the tips on lifting the cab off, I will need to do the cab on my '53 before too long.
Old Feb 14, 2025 | 06:25 PM
woodsmoke's Avatar
woodsmoke
I did the same as 56panelford. Except I used a chain hoist and tree limb. 4x4 though cab with 3" lifting straps.
Old Feb 14, 2025 | 06:43 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
My 2 cents:
I agree with the others. This rig is easy to build, if you have the hoist.
1Perry58
Jul 5, 2020 01:19 PM
82_F100_300Six
2004 - 2008 F150
Aug 23, 2019 07:50 PM
GoldCo
Nov 5, 2016 12:00 PM
Atkinsapproved
2009 - 2014 F150
Oct 14, 2016 04:57 AM
SCD
Oct 4, 2010 05:46 PM
