Odd shaped head gasket
Old Feb 9, 2025 | 11:44 PM
HertzHound's Avatar
HertzHound
Why is this head gasket not a simple circle? What’s the purpose of the design? How do you measure it if you are trying to figure out what compression ratio you had?
A little off topic topic but, is it too much work to try and figure out what Comp Cam I put in thirty years ago, or just bring it to the machine shop. I’m not planning on reusing the cam. I would like to know what my compression ratio was before a rebuild. I CC’ed the heads and piston tops. I measured the bore and stroke. Is there anything else before I pull the rest apart?
Old Feb 10, 2025 | 07:56 AM
manicmechanic007's Avatar
manicmechanic007
Those are valve reliefs
It is for an engine with bigger valves
Your cylinder walls would also be chamfered if it was needed for the valve reliefs
So that is possibly a boss 351 gasket for 4bbl heads that have bigger valves
My boss 302 head gaskets look the same (not round) and have the valve reliefs
The head gasket will still work (seal)
You'll lose a little compression and might have a hotspot
Old Feb 10, 2025 | 11:15 AM
HertzHound's Avatar
HertzHound
Thanks. That makes sense. I’ll have to make sure I don’t make that mistake again.
iIt’s probably a waste of time for me to figure out what compression I had before, since I’ll be rebuilding it. But I would like to know what I had before so I know what to expect excitement wise when I get to run it again. Maybe I’ll try and CC it with the kit I just bought, instead of using the thickness and diameter?
Thanks again.
Old Feb 10, 2025 | 03:49 PM
Crop Duster's Avatar
Crop Duster
The Fel Pro performance gaskets are +2 cc some of the thicker stock replacements are around +3 cc.
slurpeemcflurpee
Feb 2, 2025 05:03 PM
luckydoggy
Nov 20, 2008 10:20 AM
40LUTZAG
1997 - 2003 F150
Sep 28, 2006 12:57 PM
fried_guy
4 Cylinder Engines
Oct 29, 2004 06:54 PM
yemarp
Aug 10, 2003 07:18 PM
