Fuel lines
Old Feb 8, 2025 | 06:24 PM
Tylerinator's Avatar
Tylerinator
Fuel lines
Finally getting to the time to install fuel lines and tanks back into my 77 f150.
Ive got 2 questions regarding the fuel system in this truck.
1. Ive got the fuel tank behind the seat and the tank under the bed of the truck. Ive been suggested to get rid of the tank behind the seat as a safety precaution... It would make it easier to do the install but what are your suggestions
2. Old fuel lines had seen better days and half of it was rubber hose. I want do to a good job at this but I dont know the best route to go. Rubber hose is ofcourse cheap and easy but I wouldnt mind something cleaner. Is there an easy way to do stainless steel lines? Or should I go stainless flex lines? Very open to ideas
Thanks!
Old Feb 9, 2025 | 06:54 AM
FuzzFace2's Avatar
FuzzFace2
I dont see the need to remove the tank from inside the cab.
What is the safety issue of it staying? If the sender gasket and the rubber filler hose do not leak then what's the deal?
For the line(s) figure when size the old metal line is and get a coil of ALUM. line the same size. You can get it thru Summit Racing.
Also pick up a small tubing cutter from a hardware store, makes for a nice clean cut.
I ran ALUM line on a project car from rear to front, like 20 feet!
I used the old rusty metal line as a pattern. Every few feet I would bend the ALUM. line and use wire ties to hold it in place and moved down the line bend, tie, etc.
Worked pretty good and only had to make a little change to make it fit where the metal line was run. Because it was the same size line the factory holders worked too.
Dave -----
Old Feb 9, 2025 | 11:19 AM
tbear853's Avatar
tbear853
If I was happy with the range of my truck with the 19 gallon under bed rear tank, I'd rather use the space behind the seat for storage, but then I'd want to plug that fuel filler hole in the cab, even if a dummy fill cap. I've had two Chevrolets, both had in cab tanks behind the seat. I spent a lot of time and miles driving the bosses F-350 in the '70s with in cab tanks. Never smelled any fuel. If I was redoing my lines, I would likely use steel or a copper/nickel alloy that bends, flares than steel, and it doesn't rust.
nlareau
Aug 1, 2011 02:01 PM
opnjim
1997 - 2003 F150
Aug 5, 2009 09:09 PM
cowmilker08
Jun 10, 2009 03:13 PM
misnomer
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Dec 27, 2007 02:26 PM
oakwith
Sep 27, 2007 06:08 AM
